uhoh_45 Posted October 5, 2010 Report Posted October 5, 2010 does anyone run audioque's SDC2.5 15s???? wondering whats the most you put to yours and how the sub is overall R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Playa Named Joe Posted October 5, 2010 Report Posted October 5, 2010 I've had two. Only ran one at a time. The first one I blew within two weeks because I didn't know what clipping was, and it took a fully clipped signal for about 20 minutes before it started to smoke, I backed off and it last about another month, but you could hear the coil rubbing, so I gave it hell on 10 hz and it stopped after about 5 minutes on 10 hz full tilt. My second one has lasted a long time, it gets really low after it's broken in. It took me about 2+months to break it in on a Rockford Fosgate T1000 - 865 rms at 2 ohms. I have beat the hell out of this sub, but kept the signal clean (to my knowledge) and it hasn't gotten smelly yet. I would recommend them. My SDC2.5 15" gets louder on 865 rms then my Fi BL on 1345 rms in the same box. Although, I believe it maybe a little bit peaky. I hope this helps. 1994 Pontiac Grand Prix build
Riff Raff Posted October 5, 2010 Report Posted October 5, 2010 id like to know this too,thinking about selling my 2 aq 18's and getting 4 sdc 15's on my 2 aq 2200 01 Tahoe Big 3 20 ft.1/0 streetwire under hood 4 Batteries Stock Battery and 1800 Kinetic Batt under hood 2 Sprinter S12V500F Battery,165 AH Kicker 1/0 going from front to back Sirius sportster Alpine 9886 Kicker 650.4zx mids and highs Q-Logic kick panels w/Kicker6 1/2 comps. XXX re comp 6.5 in front doors Alpine6.5 coax in rear doors 2 Audioque 2200d strapped 2 Audioque 18 HDC3 5% all the way around 2 layers raamat on roof doors covered in raamat
cheese20323 Posted October 5, 2010 Report Posted October 5, 2010 They seem like good subwoofers 92 Accord Build
uhoh_45 Posted October 5, 2010 Author Report Posted October 5, 2010 I've had two. Only ran one at a time. The first one I blew within two weeks because I didn't know what clipping was, and it took a fully clipped signal for about 20 minutes before it started to smoke, I backed off and it last about another month, but you could hear the coil rubbing, so I gave it hell on 10 hz and it stopped after about 5 minutes on 10 hz full tilt. My second one has lasted a long time, it gets really low after it's broken in. It took me about 2+months to break it in on a Rockford Fosgate T1000 - 865 rms at 2 ohms. I have beat the hell out of this sub, but kept the signal clean (to my knowledge) and it hasn't gotten smelly yet. I would recommend them. My SDC2.5 15" gets louder on 865 rms then my Fi BL on 1345 rms in the same box. Although, I believe it maybe a little bit peaky. I hope this helps. what size of box do you have your sub in? id like to know this too,thinking about selling my 2 aq 18's and getting 4 sdc 15's on my 2 aq 2200 and that right there really helps out as well i'm planning out a cheap build for my buddy consisting of 6 SDC2.5's and 2 AQ2000's possibably 8 subs R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Playa Named Joe Posted October 5, 2010 Report Posted October 5, 2010 If I recall correctly, about 4^3 ft tuned to 36ish on paper. Sub is up, port is currently forward. I did have port backwards, I was curious one day and turned the box around and it kills the lows so much better now. 1994 Pontiac Grand Prix build
Playa Named Joe Posted October 5, 2010 Report Posted October 5, 2010 I have a few videos on my youtube channel. http://www.youtube.com/user/WTIFmyName?feature=mhum 1994 Pontiac Grand Prix build
d-REW Posted October 5, 2010 Report Posted October 5, 2010 they are good subs i had a single 12 and it got loud and deep but they dont like more then rated power so if you have a lot of power might wanna look at another sub. tuTWENTY * Team MechMan * Team Shok * Team Sundown
uhoh_45 Posted October 5, 2010 Author Report Posted October 5, 2010 they are good subs i had a single 12 and it got loud and deep but they dont like more then rated power so if you have a lot of power might wanna look at another sub. i think i'm good on that 3 subs per 2200 at 1.3 ohms with rise should be just around rated R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
mlstrass Posted October 6, 2010 Report Posted October 6, 2010 Running 2 12's off a SD1500 at 14+volts, and they take the power fine. Solid subs for the money. Built a few set ups with 2 15's off an AQ1200, impressive budget set ups for sure.
