High db or spl and fuel tanks
shouldnt matter.
There will be some minimal vibration on the pump parts, but should affect it unless you are in the mid to high 160dB range. Which I doubt you will be.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
If you manage to get air bubbles in the lift pump (by frothing the fuel due to flex) there may be a cavitation issue caused, but other than that you'll be fine.
On an interesting note, the engines in the 1958 MGA Twin Cam's had a resonance issue which caused the fuel to burn "lean" at certain RPM's... in short they killed engines easy :P
The article sucks btw, but this bit of it does bring up an interesting thought.
http://www.time.com/time/specials/2007/article/0,28804,1658545_1657867_1657786,00.html
Hammerdown... 1%
Thanks for the advice guys, nice article too. Mg make a nice looking car but crap engines. I never thought Acoustic resonance could destroy a motor, very interesting. I have a cast iron block so I'm good there. I was a little worried about all the slushing of fuel and how the car would smell with the system cranked and fuel breather pipes working overtime.
  • Who's Online   0 Members, 0 Anonymous, 5145 Guests (See full list)
