After looking one 12volt and the wiring diagram; I wanted to ask if this is correct or not. This was a quick draw up in paint.
What I want to know is if this will end up giving me a 1 ohm load. I have the terminals in my box and would rather not have to drill and not use them. That is why I put them in the drawing. If this will not work can someone please tell me what will?
here is the link to what i used.
Wiring link!
2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012drew.png
no. this is for converting dc to ac. useful if you want to run a blender inside your car.
Wiring link!
If you do what you have in the picture to individual amps you will see a 2 ohm load. If you do what the diagram in the link shows and wire both subs to 1 amp you will see a 1 ohm load.
so what would i need to do to get a 1 ohm load? and this will go to the same amp
**EDIT: I didnt explain this all the way i dont think.. the red terminals are going to be run to an amp.. a pos from each and a neg from each. Sorry if I messed that up.
Edited by drewb53
alright i get that.. i guess what i am asking is do you just put both the speaker wires in one terminal? Pretty much what i am asking is how do i go to 2 subs with a single pos. and neg.
If you look at the picture it shows you how and you end up with 1 pos and 1 neg to wire to your amp. Just copy this diagram exactly when you are wiring your subs and you will get 1 ohm.
Explanation.....wire + and + and - and - on both subs together with jumpers. Now take another jumper and wire/jump + on one coil of both subs and - on the other coil of both subs. Then from your last jump take another wire and go straight to your amp.
This is the hard way to get down to 1 ohm.
This is the easy way
If you just wire both subs like this down to 2 ohms and take both positive and both negatives and run them into the sub output on your amp you will end up at 1 ohm.
Edited by CJ18
so what your saying on the last part is if i did it that way, that i would have one pos. and one neg. from each sub, then i would put them both in the same speaker terminal or seperate ones? Im sorry for all the questions it is my first time with dvc subs i only had svc before.
  • Who's Online   0 Members, 0 Anonymous, 2115 Guests (See full list)
