It's simple not hard. Just connect the wire each - and + in parrallel. For example the first picture's correct and your sub are 4 ohm dual coil. Just make another wire and hook up the negative post that isn't connected.. IF you know what i meant..
are you asking how to wire the subs up in the box? If you are then wire them up like the pic above that shows a 2 ohm load. then once you have both subs wired to the box that will leave you with a positive and negative in each terminal on the box. From the box connect a wire from the pos from one terminal to the pos on the other terminal then a wire from either one to the pos on your amp....repeat for the negative side.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
Well i think i just decided that i will just go ahead and do the bolts into the box and do it like that. So i am going to do a quick draw up of it in paint and i will post it in a sec. i believe that i have this right now.
2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012drew.png
no. this is for converting dc to ac. useful if you want to run a blender inside your car.
Anyone? I need to get this figured out how I am going to do this.. And the solid little bit fatter red and blac wire are the bolts.
This is what someone recommended on caco and i wanted to get a second opinion. This is my last drawing i will do.
that is right al pos 2 one and all neg 2 other give su 1 ohm
2 C2 Audio 12s
2 Apsm 2000
2 Powerware batteries
Big 3
2 runs 1/0
Pioneer Deck
145.4 dbs
Thank you! Now i can order my wiring to do this and it will all be ready for when i get the subs.
  • Who's Online   0 Members, 0 Anonymous, 2827 Guests (See full list)
