AA98hoe Posted November 23, 2010 Author Report Posted November 23, 2010 to try and fight rise round everything inside the box. and where port comes into the cabin. not sure how much room oyu have back there ... i put 2' pvc on the edge of my port the inside is semi 45d and im off my doors with my port roughly 7' the thickness of a d3100 Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
ALPINE408 Posted November 23, 2010 Report Posted November 23, 2010 Sorry to tell you this but the loudest in dc in nor cal is 170+ db drag in upper lake with 1 18 lvl 5 Quote Have you ever had your woofers blown?
AA98hoe Posted November 23, 2010 Author Report Posted November 23, 2010 Sorry to tell you this but the loudest in dc in nor cal is 170+ db drag in upper lake with 1 18 lvl 5 thats fine! and kool, any other info on that setup? and what about street 5 in meca, am i still the loudest in cali? Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
ALPINE408 Posted November 23, 2010 Report Posted November 23, 2010 Ya of course the 170 + is an extreme car owner Jim Jean and yes your holding down street 5 in Cali Quote Have you ever had your woofers blown?
MarioB Posted November 24, 2010 Report Posted November 24, 2010 Ya of course the 170 + is an extreme car owner Jim Jean and yes your holding down street 5 in Cali Damn 170 with 1 18" is it one of those lil smart cars DAMNIT! Quote 12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodcsoundlab.com Quality is all in how you take pictures I have plenty of projects that look WAY better on camera then in person crazy to fit so many in so little. Reminds me of some of the porns I've seen?
