yikes
R.I.P!
(Nov-29-2009)
92 explorer
current build
umm... try cleaning up some wires. putting the same subs in the same box. and... put the battery somewhere where it wont fall over and short and blow all your shit up lol
apparently you dont get the fact that the subaru was wrapped around a pole. and by the status of your comment, im guessing your mouth is too.
Vehicle: 1997 Honda Civic EX
Exterior: 55w 5k Headlights and 35w 3k JDM Fogs. Lowered. Sittin on steelies right now
Amplifiers: Rockford Fosgate P450.4
Batteries: Kinetik HC 800
Electrical: Big 3 in 1/0
Enclosure: n/a : (
Headunit: Clarion VZ409
Mids/Highs: Pheonix Gold Rsd6.5's in the Front Doors
Subwoofers: n/a : (
Wire: Knukoncepts 1/0 and 4g
Future Upgrades: 20% tint all around, GC/Koni coilovers, body work (fml) lol
man if that is a lead-acid battery in the back with you, i would suggest taking that out before it does some serious damage to your health. also, dont spark any flames in your car lol. im not sure if those fumes ignite or not.
edit:
look at the warning on it! DANGER/POISON! and then under the handle it says "GASES" NOT GOOD MAN!!!!
Edited by dugee81
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
fix the exposed wire, and replace the cracked wire
R.I.P!
(Nov-29-2009)
92 explorer
current build
bro this is scary
im gonna have nightmares
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
lol i want to clean everything up a bit but ripping up these carpets will be hard. for some reason all of the screws for the carpet are stripped. and the battery i want to get a pan for it in a junkyard ot something i know its bad in the back like that.
Veng.
Bro seriosly. Get that battery out of there, and get new wires. This is a death trap on wheels. i don't think you understand. Theres 2 major faults with that battery. One it's just sitting there. if you hit the brakes hard ot crash that bitch is coming for your head. And 2 those batteries give off a harmful gas that can kill you if exposed to long.
Edited by Alex K
2006 Nissan Z Track.
My Feedback Thread
