Your thoughts about Hifonics 2500D
Carroot1
agm battery? and my box is 3.5cubes, it cant get any smaller. Plus with all the bad luck ive been having im not to fond of another box build.
agm = absorbed glass mat. kinetik, XS, Shuriken, Deka G31, uhm optima G31, etc etc
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
How come they cost so much more?
because of the type of battery they are and their intended purpose! they are geared way more towards car audio applications, and will last way longer in a car running a sound system as compared to a normal car battery. normal batteries dont really like to constantly be drained/recharged and it leads to premature failure.
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Since my original car battery is in the trunk I would replace that with one of those batteries and just leave the 2nd one under the hood for all the other needs?
They hold voltage a lot easier and longer, and if you really look at wieght even, there about double regular battery. There expensive, kinda, worth it, definitly.
x2, also a typical lead-acid battery needs to be in a well ventilated area(such as the engine bay or you should vent it to the outside if it is in the car. I love my AQ 2200d its a very solid amp that does rated power. Its also rated at 12 volts which means if you can keep your voltage up around 14 it will do more than rated.
TDH FTW !!!
I will probably get a new battery for christmas
WOAH. is your battery isolated from the cabin? normal lead-acid batteries expel fumes that can harm you if exposed for a prolonged period of time
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
i had acid batteries in the trunk of my hatchback car and i´m still alive hehe, yes it expel fumes but when you live on a third world country where a gel battery cost you 700$ dollars you have to get other choices hehehe
there is a wall between the trunk and the back seats... makes my subs a lot quieter, thats why I want more powa
