merk_master Posted October 16, 2010 Report Posted October 16, 2010 Ok so I am looking to compete on a near non existent budget for MECA S1 in 2011. I am gonna have to pull something out of thin air in order to even be competitive.Mt car is a 2002 Ford Focus Sedan Im only going to be able to use 200 watts Rms per subwoofer. this is the amplifier specs I have * 760 x 1 watts peak @ 4 ohms * 250 x 2 watts peak @ 4 ohms * 190 watts RMS x 2 @ ohms * 380 x 1 RMS @ 2 ohms * PWM Regulated MOSFET Power Supply * Bridgeable 2/1 Channel amp * Hi-Volt Input Level Control (400mV-6.5V) * Balanced Isolator Input Circuit * Oversized Screw-Type Power Terminals * Molex Type Speaker Level Inputs * Selectable 80 Hz Low-Pass Filter (12 dB/octave) * Switchable 50 Hz Bass Boost (0/6/12 dB) * Amplifier Type: 2-channel * RMS power @ 4 ohm: 125W x 2 @ 14.4V * THD @ 4 ohm RMS power: <0.015% * Bridged RMS power @ 4 ohms: 380w x 1 @14.4V * Speaker level inputs * Frequency response: 10-50,000 Hz * Signal to noise ratio: >95dB * CEA-2006 compliant * Bass Boost: 0 - 12 dB * Requires 4 gauge amp kit for installation * Fuse Rating: 30A x 2 * Dimensions: 10.5" L x 13-5/8" W x 2.5" H The Subwoofers are Pioneer 10's * 10" high powered sub * champion series! * 1,000 Watts Maximum Power * 200 RMS Rating * Frequency Response: 20-180 Hz * 93 dB Sensitivity * IMPP Composite Cone for strong bass response * 32 Oz Strontium Magnet * Wide-Roll Dual-Layer Urethane Surrounds eliminates distortion * 6-Layer Single Copper Voice Coil * Projected Pole Yoke with Vented Pole for even and strong sound * Stamped Basket * Magnet Cover * Push Terminals * Nomex Spider * 4 Ohms Impedance * Mounting Depth: 5 1/4" * Sealed box volume: 0.55 - 0.69 cubic feet * Ported box volume: 1.0 - 1.25 feet Would I be able to compete in S1? also would a ported box sealed off in the fold down seat opening be good? It would be Subs and Port facing forward . Quote hopeful noob
Jbabycsx Posted October 16, 2010 Report Posted October 16, 2010 What type of amp it that? Quote 2000 GMC Sonoma AQ20 FTMFW! 4 DC XL 15's Cadence ZRS-C9 Infiniti Kappa 3.5's and 6x8's Bravox 6.5 components
EclipseChris Posted October 16, 2010 Report Posted October 16, 2010 would a ported box sealed off in the fold down seat opening be good? It would be Subs and Port facing forward . Yes, tune high. If you know your car's resonant frequency tune it around there. If you don't, find out. Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
ingramcaraudio Posted October 16, 2010 Report Posted October 16, 2010 Why not run as1? Quote Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
merk_master Posted October 16, 2010 Author Report Posted October 16, 2010 I know Resonanating frequency is roughly 43-46 hz. The Amp is also a Pioneer .I could compete in AS1 I just figured S1 was same rules/guidelines. Wont tuning high kill any chance of any music response ? I know Sine it would be loud Quote hopeful noob
ingramcaraudio Posted October 16, 2010 Report Posted October 16, 2010 You would just have easier competition in as1 and it'd give you a chance to learn. Quote Facebookhttp://www.facebook.com/#!/pages/Farmville-VA/Rockwell-Audio/103036213076623?ref=ts
merk_master Posted October 16, 2010 Author Report Posted October 16, 2010 ok pioneer includes specs for a bandpass enclosure for their woofers would that be better? keep in mind I would still like to listen to music with it Quote hopeful noob
EclipseChris Posted October 16, 2010 Report Posted October 16, 2010 If you wanna get numbers for nothing make the car a burper. If you want it to play loud on music and sound good then get money and forget about competing. It is that black and white. Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
merk_master Posted October 16, 2010 Author Report Posted October 16, 2010 If aeroPorts are allowed I could run 2 4" aeros 6" long for 46 for comps and plug one for 34hz for music? Quote hopeful noob
fmedina Posted October 16, 2010 Report Posted October 16, 2010 Yes, tune high. If you know your car's resonant frequency tune it around there. If you don't, find out. how do u find out Quote
