Dvldogyut Posted October 18, 2010 Report Posted October 18, 2010 Will xs power d2400's fit in my stock battery boxes?
AA98hoe Posted October 18, 2010 Report Posted October 18, 2010 what year? on my 98 the 2400 sits kind of high so i had to use the side post adapters so the hood mouldnt hit the terminals. but the 3400 fit perfect so id go with 3400s TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Dvldogyut Posted October 18, 2010 Author Report Posted October 18, 2010 what year? on my 98 the 2400 sits kind of high so i had to use the side post adapters so the hood mouldnt hit the terminals. but the 3400 fit perfect so id go with 3400s Oh my bad it's a 2001.
Nathan @ XSpower Posted October 18, 2010 Report Posted October 18, 2010 The 3400 would fit in the stock location with no modifications, but with some modifications you can fit as big as a D3100 under the hood. If you are still running side posts, then with the 3400 you would want to use the Ibar Kit 551 or 555.
Dvldogyut Posted October 18, 2010 Author Report Posted October 18, 2010 The 3400 would fit in the stock location with no modifications, but with some modifications you can fit as big as a D3100 under the hood. If you are still running side posts, then with the 3400 you would want to use the Ibar Kit 551 or 555. Where is the best place to buy a couple of 3400's?
MECHMAN Posted October 19, 2010 Report Posted October 19, 2010 I have them in stock for $239 SHIPPED anywhere in the 48 states. I believe that is the lowest shipped price you will find. Just give me a call, or PM me. Matt 1-888-MECHMAN www.Mechman.com [email protected]
