I have a orion hcca 12" in 2.5cu box ported tuned to 34htz I had an hifonics xx-colossus which is 3200rms at 2 ohm and my sub is dual 4 wired to 2 ohm it was loud and moving the sub but no where near the 4" excursion it should be getting. So I'm looking for an amp capable of 4000+ rms at 2 ohm. I am highly considering the autotek mm4000.1d which is 419 shipped (refurb). Does anybody have any more suggestions of amps.
www.wooferwarehouse.com
You could try it.. I also have a HCCA on a colossus @ 4 ohms.. Looking to recone and get it down to 2 ohm. You haven't had any problems feeding it 3000 watts? What's your electrical like?
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Nope it was barely moving for me 125amp alt stinger battery in the back 4 ga and staying about 13.5v when bass hits
Try the AQ 3500.1D it puts out 4300rms on good electrical.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
More information and specs to the box. I've never been able to feed more than 2000 watts safely to the hcca.
Also, are you sure you're wired at 2 ohms? What's the electrical like and are you sure the amp is seeing sufficient current? Also, how new are the subs
That's also at 1 ohm
Box is 2.5cubes sub wired to 2 ohms voltage stays around 13.5v when bass hits bought sub used said he used em for about 3 months
Well I read that part...port? Was the box built or bought used also?
I had a box builder in my area build it for my sub and idk the port size info.
