Okay, So I managed to steal one of these amps....
I got it for 160, and it came with a Cerwin Vega 124 [12in dual 4 ohm 1000watt rms] in a prefab ported box...
Only using the amp...
Anyways...
So I've looked around, and I'm sure this amp is putting out over 1000 RMS... like EASILY....
So I set it with a DMM at 50hz for 1200...
Am I safe? as in not clipping.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
whats your volts at?
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Anyways...
Thats a good deal
You should get a custom one if you wanna use this setup as a daily driver
Yeah, but not TOO much over..its in the SAE line, not SAZ
Whats your voltage at full tilt
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Fuxkin genius right here.
Haha..thanks Chris :D
LMFAO so true
:blush:
If you tried to set it for 1200 watts, its safe to say you are clipping the sub. From my own prior experience (and yes i have a damn o-scope) you will start to see a dirty pattern around 1050 watts depending on your input signal and voltage drop. If you have no idea where your head unit starts to throw out a clipped signal, if it does, then you could be clipping a lot worse than you think.
Find someone with an o-scope, set it up correctly, and save your equipment and your wallet some money. You will thank yourself later...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Thats a good deal
Fuck yeah it is. :woot:
It's sitting in the garage... Probably gonna sit for a while or get traded for an iPod
Well dayumn....
With it sett at 1200 at 1 ohm by DMM at 50 hz... I have no voltage drop at 2000 rpms... I basically only listen to low bass and decaf.
well what do your volts rest at?
I have an o-scope, but there's no way what it's saying is correct, it's saying my deck doesn't clip even at full tilt, and it's also saying the amp is clipping when i BARELY turn up the gain... It makes no sense.
  • Who's Online   0 Members, 0 Anonymous, 1707 Guests (See full list)
