Atomic 7k help ASAP please
fox_racin4
running an atomic 7k, on the way to a buddies tonight the amp would shut off i would turn deck off and back on and all was good ( happend twice ) on the way home it happend again pulled over amp was in protect shut deck off and back on didnt switch shut car off and back on amp was on ( green ) then heard a pop from both amp and sub
got home pulled the amp opend it up and there is NO burn marks anywhere my brother said he seen a spark/light from inside when amp went pop but... theres no makrs anywhere no funny smalls nothing
help please!!
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Umm how did you bench test it, just out of interest?
Are you running a rear battery setup? Half the time it's cos you've somehow popped one of the fuses on your feed front-back and the back batts have gone flat. Check the voltage.
Other things that will make these amps all protect happy are bad grounds on anything in the signal path like EQs and the such.
Last of all, it might have just shat itself. They do that from time to time.
10.x volts fo' life!
bench tested with kinetic 3800 8g inputs 12" long or so
in car rear batts only fuses are from batts to amp nothing between front and rear will cheak voltage in the rear
Sorry, but that's like... the most pointless thing I've ever heard. Why fuse the runs to the amp? Especially if you're not fusing the run front-rear. If you're not gonna fuse the single most important wire in the car, why fuse anything?
  • Who's Online   0 Members, 0 Anonymous, 1246 Guests (See full list)
