NO!
Brass won't have that problem like other metals will.
yea they put all new brass ones in. the factory ones looked aluminum or some type of gray metal maybe tin. thanks
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I can see something going on if it were tap water in the engine and anything but brass freeze plugs but now that you have the brass ones you'll be set for many years without having to worry about them.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I use this process to take rust off of parts for my Camaro and I have to use baking soda for the process to work. How would it happen in a cooling system without it? Just curious.
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Infiniti Kappa 3.5's and 6x8's
Bravox 6.5 components
unless u have current going INTO ya cooling system there is no electrolysis. now if u do SOMEHOW have electrolysis going on i wouldnt be worrying about just freeze plugs but everything that is being touched by the liquid. get another opinion from another shop and see what they say.
I know a lil about everything so dont call me Mr. Know it All.
It's highly doubtful you are causing the problem with the electrical. A couple of things I would suggest is to use Deionized water to mix with the coolant and switch the type of metal. Which I have seen you have already done one of the two.
Some metals oxidize faster than others and are more conducive to corrosion. An good example is aluminum and a oxygen rich environment. Most likely the plugs were inferior metal.
I could ask some of the electrical engineers at work if you would like. By the way I am an civil engineer and the courses I've taken would lead me to the above comments. Moreover, prior to my engineering degrees I was also a pipe fitter for 14 years. In my experience 95% of the time corrosion is caused from an oxygen rich environment and chemical reactions not electrical reactions!
Edited by Soapbox
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
  • Who's Online   0 Members, 0 Anonymous, 2696 Guests (See full list)
