There has to be an easy way to do this but I cant figure it out. Every time I get 4 sides done and use the push tool to get my 3/4" with no problem.
But when I go to put the top or side on it want's to fill in the whole area and I don't want it to.
Can you enplane this process to me. Thank You
draw the bottom. push/pull to size. draw the 4 sides ON the bottom with the line tool. push/pull them to height. top gets tricky. you have to make it to the side and then move it to the box.
Ok, ill try that. And I have done that before where you draw the top separately then move it over but I thought there was an easier way.
