looking for a 4 channel amp for my door speakers (4 mb quart 4 ohm speakers). my friend has a sundown audio 100.2 for sale, can i use this 2 channel amp to power 4 door speakers? any suggestions would be helpful.
it would have the same output as a deck....
get an xplod 4channel off craigslist.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
well IIRC, 100x2 @ 4ohm & 200x2 @ 2 ohm ? 400x1 @ 4 ohm bridged? maybe that amp isnt capable of that.
i ran 4 speakers off of a little hFI zues amp that had the same specs, all wired down to 4 ohm bridged to the amp
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
That amp would be fine, you run 2 speakers paralleled to each channel, rated at 200rms x2 at 2 ohms.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
You sure? 100.2 spec below:
100 watts x2 @ 4 ohms stereo
200 watts x2 @ 2 ohms stereo
400 watts x1 @ 4 ohms bridged
Wiring each side of the speaker in parallel [(FL/RL = 2ohm) and (FR/RR = 2ohm)] to one channel each will yield 200w each. You can do it, but up to you.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
lol htf can you compare 15w to 100w per speaker the sundown should do great i have a zapco 750.2 running 6 61/2s and 6 tweeters and it screams
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
dude, that would be sweet if i can run my 4 door speakers with the sundown 100.2 that is an awesome amp from what i hear. my friend wants $150 for it, this would be better than buying a cheap 4 channel amp, right?....
4 channels are good and meant for different sized speakers that need different crossover points imo. but i like 2 chan cause you get more power to the speker and they get louder. id go with the sundown if i were you. i just bought another zapco 750.2 for my highs for $180 and i dont even need it just couldnt pass it up. :)
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
lol look at his name banginonabudget. he must run walmart xplod in his ride. that amp will be fine it puts out more than rated
2015 silverado crew cab
nothing atm but soon...
