big dee Posted October 24, 2010 Report Posted October 24, 2010 i just bought a bagged chevy truck and i cant get it to go up in the back . but it went down fine? i checked the swicth and its good. this is my first air ride so im lost can any one shed some light on what im doing wrong or what i can check? it only has front and back.
BeachJoshua Posted October 24, 2010 Report Posted October 24, 2010 You bought a truck that was bagged and didn't have it demo'd? | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
Sanitarium Posted October 24, 2010 Report Posted October 24, 2010 You bought a truck that was bagged and didn't have it demo'd? this. pull out a dmm and start checking wiring and switches.. or shell out some more cash and have someone else look at it.
big dee Posted October 24, 2010 Author Report Posted October 24, 2010 it worked fine . and i took it out today and it did fine but when i got home and layed it down the back wouldnt go up again . i check the wiring and the switch. seems to be fine. what eles could it be
rusty959 Posted October 24, 2010 Report Posted October 24, 2010 I would suggest you start learning how air suspension works. It's pretty simple and once you know how everything interacts it should be pretty easy to start some simple troubleshooting. If you don't hear a leak when you hit the switch it is probably something electrical, whether that is a switch or wire bad/loose or a bad valve. 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
big dee Posted October 24, 2010 Author Report Posted October 24, 2010 I would suggest you start learning how air suspension works. It's pretty simple and once you know how everything interacts it should be pretty easy to start some simple troubleshooting. If you don't hear a leak when you hit the switch it is probably something electrical, whether that is a switch or wire bad/loose or a bad valve. well you have to start some were.
big dee Posted October 24, 2010 Author Report Posted October 24, 2010 im kinda learning as i go . you can hear the valve to drop it but it dont make any sounds when i try to raise it. theres no air leaks
rusty959 Posted October 24, 2010 Report Posted October 24, 2010 Exactly. Just surf around (here and other places) to get a good idea of whats going on. For example, here is a diagram that might be of some help if you don't already understand what it is showing. If when you flip the switch the terminals on the valves show a voltage, the valve should open. That would be a good place to start your check. How did you test the wiring? 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
big dee Posted October 24, 2010 Author Report Posted October 24, 2010 thanks man. do you have a diagram for the wiring for a f b system.
rusty959 Posted October 25, 2010 Report Posted October 25, 2010 Not without searching. Its the same as any other one just with less valves. 2013 Subaru BRZ12" Orion HCCA on AQ 22001967 mustang restoration project: http://www.stevemeadedesigns.com/board/topic/110765-mustang-restoration-build-2011-edition/ Youtube: https://www.youtube.com/user/therusty959
