96HOE Posted October 26, 2010 Author Report Posted October 26, 2010 Dc98hoe where have you gotten best results as far as your ground points for the big 3... And also yes I am planning on adding more amps (2 more 2100s for the lows, 1 more 2100 for the mids, and not sure what I'll use for the highs yet...
96HOE Posted October 26, 2010 Author Report Posted October 26, 2010 My mounting setup is the same as yours in your 98 I got the vortec 5.7 in her as I'm guessing you do... So I may just be stuck with a triple?? And do you think I should drop some power somewhere then? And also I've done a little looking at alts but I may as well ask since you got the same truck for the most part... What's the biggest alts you've found for our bodystyle?
hdorre Posted October 26, 2010 Report Posted October 26, 2010 not sure on your mounting setup for your year tahoe. no one makes a quad ,dom did a one off for lame dude jp,Dc only does a tripple for my year thats what i have. maybe mechman but all ive heard is hes doing doubles. most quads are for 2000 and up. Doesnt JP have 6 alts? On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
AA98hoe Posted October 26, 2010 Report Posted October 26, 2010 go from front battery down to frame section by etween radiator and motor there should be a flat spot there then depending on your alternator mounts put one on one of your mounting bolts to same spot on frame. then i beefed up my factory wire to 0g from battery to inner fender. if you can in back ground battery on same side as frame as you did in front and do 2 runs if you can then ground amps to battery negative. of course amp positive to battery positive. i just bought 5 more runs of 0g that im going to use as negative runs front to back. ill post if there is a big difference a wise man once told me think of your power and grounds as a flow of water. what would be the best flow with the least resistence? copper is a way better conductor than steel, so if you you wire instead of the frame it will flow better. but the frame does do the job just not as effecient TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
AA98hoe Posted October 26, 2010 Report Posted October 26, 2010 Doesnt JP have 6 alts? yes he does he has iraggis quad and DC dual TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
AA98hoe Posted October 26, 2010 Report Posted October 26, 2010 My mounting setup is the same as yours in your 98 I got the vortec 5.7 in her as I'm guessing you do... So I may just be stuck with a triple?? And do you think I should drop some power somewhere then? And also I've done a little looking at alts but I may as well ask since you got the same truck for the most part... What's the biggest alts you've found for our bodystyle? at first i ran a220 then 2 280s. but i just sent my 280s back to dom last week to make them 220s. why bigger isnt better my voltage dropped at idle where i do most of my demoing and competeing. so the 220s put out most amperage at idle for me 185amps. the 300a or more alternators put out shit at idle TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
anubis Posted October 26, 2010 Report Posted October 26, 2010 not to go off topic...but why tune that low...the btl handle that without f'n up? 1998 Monte Carlo Z34 Stock HU but have replacement Stock Highs Stock Electrical BTL 18 sitting naked AP1500D
96HOE Posted October 26, 2010 Author Report Posted October 26, 2010 Actually they sound pretty crazy tuned that low even barely being able to run them... Why I did it? Rofl.. That's a good question... I guess just to try something different, I always tune em around 30-35hz and they took it with ease so I figured I'd say what the hell n give 21 a try... and yeah I usually play mine the most at idle too but I also make a lot of trips from south georgia up to minnesota... So you think maybe 3 220s would do ok? What do those put out at idle?
AMI CUSTOMS Posted October 26, 2010 Report Posted October 26, 2010 220 amp alts if you get good ones usually put out around 150-180 at idle. And for only 4200 wrms you won't need three alt setup, a dual 220 will be more then capable of running that with no drop if you have a few good agm batteries. Just read where you said you are adding more amps later, then you will need triple kit for sure I would get the three 230 amp alts and a 6-8 battery bank. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
96HOE Posted October 26, 2010 Author Report Posted October 26, 2010 Really you think 6-8 will do the job?? I was thinkin 10-12?? And yeah I plan on sitting around 16kw when finished...?
