96HOE Posted October 26, 2010 Report Posted October 26, 2010 ok so im debating on getting a stinger 50 farad cap to go along with my sk-bt120 shuriken batt or do you think i should just get another batt to help keep higher voltage in my 96 tahoe??? current equipment is as fallows and alts are in the making 2-2100rms brz amps strapped / but only able to run one of them currently due to voltage dropping super low 1- sk-bt 120 shuriken 2600 amp batt big 3 done stock alt at this time all tsunami 1/0 guage wiring 2- fully loaded Fi BTL 18s 20 cubic ft box tuned at 21hz any suggestions??? could use the help A.S.A.P. please
Skullz Posted October 26, 2010 Report Posted October 26, 2010 Alt supplies power and batteries store it, if your dropping really low then you'll need a better alt to start off with and having a small bank of batteries to store enough capacity that voltage spikes don't occur from massive hard hits from the bass. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
hdorre Posted October 26, 2010 Report Posted October 26, 2010 Batteries don't raise the initial (charging) voltage, they try to maintain it. With all that power, get the biggest alt possible and upgrade the starter battery. If the charging voltage isn't what you want, get a voltage regulator from Mechman or MLA. On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
96HOE Posted October 26, 2010 Author Report Posted October 26, 2010 Ok I have plans to do a quad alt in the "HOE" here real soon any suggestions on where to get the brackets n such? Also is my stock alt really that crappy that it can't hardly run a 4200 watt amp or should I replace that alt as well?
AA98hoe Posted October 26, 2010 Report Posted October 26, 2010 try different grounding point on your big 3 or run a negative 0g from front to back. my hoes voltage will change with different grounding points and most definetly do 2 alternators if you can. i went 3 and its barely enough. a good high output alternator will make a huge difference. plus the hifonics amps are current hogs i had 1 2008 and it would drop with a 220 amp iraggi and 4 svr 3000 batterys TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
hdorre Posted October 26, 2010 Report Posted October 26, 2010 A quad alt for 4200wrms? Or do you plan on adding/upgrading amps, because that would be crazy if It were for your current system. Try DC Power for the bracket. Don't expect it to come fast. Also ask Mechman. He may find a local Tahoe that he could test fit it in. You could look for local shops too. The stock alt probably isn't shitty. It was just made to power your TRUCK, not a ton of extra shit that the average person wouldnt even consider buying On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
dugee81 Posted October 26, 2010 Report Posted October 26, 2010 Ok I have plans to do a quad alt in the "HOE" here real soon any suggestions on where to get the brackets n such? Also is my stock alt really that crappy that it can't hardly run a 4200 watt amp or should I replace that alt as well? Its what, a 140 amp alt? Give or take 50% of that is used to maintain function in all electrical applications that come stock with the car. This gives you ~70 amps for charging and supplying, when your amplifiers are demanding 420 amps at max, give or take a little. When the alt cannot supply the demand asked, voltage will drop. When you're short 350 amps, yeah you might drop a ... Lot lol 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
hdorre Posted October 26, 2010 Report Posted October 26, 2010 When you're short 350 amps, yeah you might drop a ... Lot lol On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Socky Posted October 26, 2010 Report Posted October 26, 2010 Check out the forsale section, theres a quad alt setup for a tahoe forsell, or buy a single alt. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
AA98hoe Posted October 26, 2010 Report Posted October 26, 2010 not sure on your mounting setup for your year tahoe. no one makes a quad ,dom did a one off for lame dude jp,Dc only does a tripple for my year thats what i have. maybe mechman but all ive heard is hes doing doubles. most quads are for 2000 and up. TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
