Scion Tc Box Advice needed?!?!?!?
craracer05
OK, I'm doing a single rockford t2d215 in my scion tc. I'm trying to build around rockford's high output design. They recommend 38hz tuning but I would like to go lower I think because I listen to a lot of different music. As usual every box calculator is giving me different numbers on the port. I have a 42"Width x 13"height x 17"depth
box whichs come out to 4.1777 ft^3. Subtract .176 woofer displacement and you have about 4ft^3 even. So my port is going to be 11.5x3" and 14" deep. 12volt.com says I'm at 35hz, on here says 37hz and re comes out to 32hz. I really want 32-35hz. Can any one help me out, dimensions for the box are max you can go,I want sub up, port back aswell.
2007 Scion Tc- T1500.1bdcp & t600.4, Three P3D212's Ported at 40hz, T2 6.5" Components, Rockford Marine 8" coax's. Kinetik khc1400 in back, Kicker 0 gauge
1999 Cherokee- Rockford Prime Amps 300.4 & 500.1,Big 3, Rockford 6.5"Comp.s and 6.5" 2ways, 2 12" P2's Ported basic winter beater
2002 Mustang Convt.-T1500.1bd & 400.4, 3 P3D210's IB, JBL components all the way around,Rockford 4 gauge, Big 3, Kinetik khc800 in back
search exposport and download his calculator, hes on the forum. also, tune to 32hz.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
Ok searched it and exposport and torres box calculator are the same when I said on here I met torres and that's what is telling my 37hz for some reason where everywhere else is telling me lower 30's. Idk what to trust because there's a big difference between 32hz and 37hz...
Heres my box idea so far its in between normal and powerful specs.
Now this is the RE drawing which shows the tuning frequency way lower. This will be sub up port back.
Someone has to ahve some input I want to start building soon.....
The Torres/Exposport(same guy) calculator is accurate, the reason the RE calculator is giving you a different reading is the RE one doesnt calculate any displacements, so its giving you the reading not counting port displacement....sub displacement....and bracing displacement.
¿ǝɯɐƃ ǝɥʇ
Ok then I should be good with this box then, next question is does anyone know how khaotik enclosures gets such a smooth paint finish in their ports I reall like the the look of the super bright colored port.
