i was wondering how i would wire 6 dual 4 ohm subs and what the lowest impedance i could get i am looking to get 2 ohms can any one help me
Currently in a build
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Pioneer AVH-P2300 (next purchase)
High output alt 150 amps
wire each sub up to 8ohm then wire them back down to get a 1.33 ohm load
is it possible to wire it all in parrales then the last sub in serries to increase the impedance
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
dont get what your sayng, having one sub at 8 ohms will the rest are in 2ohms? no.
if you have any decent amp, stable atone ohm. 1.33 is perfect.
ok lol do u think there is a diagram or should i just keep playing around with the wireing and look at my multi meter
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 2275 Guests (See full list)
