victor83007 Posted November 2, 2010 Report Posted November 2, 2010 If I get a extra battery for my sistem ,,, how do I supost to charge it. ?????
moetpoppin Posted November 2, 2010 Report Posted November 2, 2010 hook it in parallel with the rest of your system you need to run a positive wire to the back You can either hook up negative to ground, or even better, run a positive and negative wire from your front battery. have you upgraded the big 3 yet? if not, start with that... ty TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log
dugee81 Posted November 2, 2010 Report Posted November 2, 2010 connect the front battery to the rear battery. drive on the highway for a little while. or purchase a trickle charger that floats when the battery is at full capacity. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
victor83007 Posted November 2, 2010 Author Report Posted November 2, 2010 hook it in parallel with the rest of your system you need to run a positive wire to the back You can either hook up negative to ground, or even better, run a positive and negative wire from your front battery. have you upgraded the big 3 yet? if not, start with that... ty . What's the big 3?????
zeus245 Posted November 2, 2010 Report Posted November 2, 2010 hai, if i were to put an extra battery, does it have to be the same size battery as the factory battery in the front?.. tanks HU: Kenwood DDX5034 front stage: Focal 165 v Slim component back stage: Infiniti 652i component amp: kenwood 4channel sub amp: sony mono 800watts peak wired to 2 ohms subwoofer: 3 12" Kenwood subs (from my old car)
dugee81 Posted November 2, 2010 Report Posted November 2, 2010 hai, if i were to put an extra battery, does it have to be the same size battery as the factory battery in the front?.. tanks not same size as much as same type.. aka if you have an AGM style in the back, it is recommended you put an AGM under the hood for most optimal performance. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Bocaj Posted November 2, 2010 Report Posted November 2, 2010 . What's the big 3????? This Car 1991 Honda Accord EX System I now have and is finally installed! Pioneer DEH-P7200HD Digital Designs 3512 Digtal Designs CS 6.5" components Audioque 2200 DD Audio C5b Optima Yellow Top Rockford Fosgate 1/0 Damplifier Pro Luxury Liner Pro
zeus245 Posted November 2, 2010 Report Posted November 2, 2010 not same size as much as same type.. aka if you have an AGM style in the back, it is recommended you put an AGM under the hood for most optimal performance. i just bought the car, n it comes with the maintenance type (top-up with distilled water).... i might wanna change to a maintenance free soon, so this means that i have to buy 2 of this maintenance free bats rite.... tanks HU: Kenwood DDX5034 front stage: Focal 165 v Slim component back stage: Infiniti 652i component amp: kenwood 4channel sub amp: sony mono 800watts peak wired to 2 ohms subwoofer: 3 12" Kenwood subs (from my old car)
