well as im working on car i figured i would also redo my big mistake from last year when i had no idea what i was doing, i moved my battery from engine bay to the trunk and used "0ga" wire, well i kind of knew it was cheap but i never seen REAL 0AWG wire before so i didnt know, well i found the source to all my voltage drop and electric problems, my old ground wire from battery to rear strut mount( let me know if there is a better place to ground battery ) and it was reading like 8-10 ohms O_O thanks to pharmacist i got some )awg wire for my ground getting all new wire soon but here is a nice comparison shot of the wire thats running from front of car to the back >.< man im stupid
the smaller wire is some Rockford fosgate 4AWG
quick update on the car, i got my ground wire upgraded finally soon doing the power wire got a nice beefy kicker battery terminal thanks to best buy reward money :-) car is gutted and ready to be cleaned for sound deadner and you can see i have a very tiny car with not alot of room to work with
wires are 0AWG welding wire and 4AWG rockford for the amps
the lonely battery
big hole from trunk to cabin was a peice of cloth but i added some fiberglass and will cover in some sound deadner to seal up
cloth that is being glassed
thats where the actual box is going
floor to be covered
door to be covered as well as other side of course
yeah i plan on gtting rid of the caps, i know they dont serve a big porpose but when i added them i noticed a diff, only spent 20 dollars each on them so im not at a huge loss , going to keep them for the time being
ok well i got all the sound deadner in the car and i have the box back in and what a difference that makes with the bass, plus adding a divider in the center port for both chambers made a HUGE difference, i didnt take all the pictures but here are some im very happy with the way the bass sounds, still waiting to finish door pods for the 2x 6.5 components on each door and waiting for the 8" reference midbass drivers for the rear as well, i got the trunk sealed from cabin and that seemed to have helped as well
also replaced all my shitty 4gauge equivilent CCA 0ga wire with all 0AWG welding wire and with subwoofers at full tilt voltage doesnt drop down past 13.5+ only running a 65AMP stock alt so im pretty happy with that
.... cant get the pictures to upload into phoobucket says network error so i will try again later
here are some pictures of what i have done so far
trunk lid, it looks like its peeling but its the angle
Box inside the car, panels are in and seats and seat belts are in still need to put the cover on the top and the boxes in for the midbass drivers
back of the trunk, turned out pretty good the fiberglass is hard as rock and does a good job sealing the trunk up
the lid that coveres the convertable top when top is down and holds the bubble top
area were top goes
amps
bubble top
doors all done, it doesnt look as good as i seen other people do but it no longer rattles
thats all i have for now more soon
quick picture of the pods so far, hopefully after this layer dries they will be hard enough, A HUGE THANKS GOES OUT TO BOBBARKER FOR HIS HELP ON THESE PODS !!!!
:good: :good: :good:
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
got some more done today, got my mid bass drivers in the mail today boxes cut ready to be assembled ( didn't have any glue ) and got 2 coats of bondo on the pods and somewhat sanded
im very pleased with the speakers since i paid 35 a piece for them, the rubber surround is very soft and does not have a very strong suspension but i did a couple free air test and no problems should sound good once in the box, box will be .27 cu/ft before displacement of speaker
the pods aren't SUPER thick but very strong don't move a bit but once they get cut open i will be soaking in some more resin where the cloth didn't soak all the way through and then one more coat of glass to finish her off.
more updates as they come, hopefully not to much longer till shes done
got some more done today was going to do more but those in Michigan can understand why
Almost ready for paint, using black truck bed liner
got them cut open to find the resin didnt soak all the way trough the fleece so we will put some more in to add even more strength to the rock solid pod
got these boxes made after about 3 tries, a WONDERFUL story behind why but i think i will keep that between me and Bobbarker lol
more to come i dont know about the 7" driver yet might switch to the 8" we will see once in car
  • Who's Online   0 Members, 0 Anonymous, 1107 Guests (See full list)
