what kinda power? imo the box is a lil to high, sounds good though
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Right now the woofer is on a DDM3@ .5. When I get the other woofer I plan to run a Warhorse or 2 SAZ-4500's each at .5. When you said u though the box was a lil high, did you mean tall or tuning? That particular enclosure was used for my old setup in which I had the Mayhems. Box is tuned to 34hz. It put up so pretty good numbers with those subs (imo) without a ton of power. That box will be coming out however with new dimensions and a whole new design. Thanks for the complement. Any advice ar suggestions?? Im always open to feedback, especially when doing domething like this :drinks:
LOUDEST PHUKN BURB N LA COUNTY!!!!
Team SoCal SPL
Team Sundown
Looking good man. cant wait to hear it. Got a little something something also. When is the next K1 show going to be? and will you be at it?
formerly known as Blue86f150
this sux camel dicks
Thanks Blue......next K1 is the 21st soooooooooooo next Sunday. I heard you had a lil something!!!! Good job n Vegas man. See ya at K1 :yahoo:
Team SoCal SPL
Team Sundown
