New to car audio/help with amp
Static
Hey guys,
I have an Orion West Coast Customs 600w 4 channel amp http://www.amazon.com/Customs-600-2dWatt-4-2dChannel-Amplifier-WCC-2d6004/dp/tech-data/B000F34GGQ/ref=de_a_smtd
and a 15" Kicker CVR-Aluminized subwoofer in a sealed box.
Am I able to make these both work together? Will it hit hard? What kind of Wire kit would I need to set this up correctly? Am I able to bridge this into a mono setup so I get the maximum power out of this amp?
Thanks for your help in advance guys!
aluminized?? what coil configuration do you have for that sub? (the model number will say either say CVR154 or cvr152 If you have cvr154, then you can bridge the front channel to a coil and the rear channel to a coil.
Orion 2500D, Jbl Gto 75.4
Team Wolfpack Audio FSQ 15" d2, mb quart xover, tweets peerless 6.5 mids
Alpine cda-105
optima up front Knu klm 1/0
I think it is a cvr 154 because it has 4 connectors on the sub
so its a dual 4 ohm woofer. it has 2 voice coils that are 4 ohms each. so you can wire it to 2 ohms only (8 ohms is unreasonable)
4 connectors mean it is a dual coil woofer. Look on the bottom of the magnet and check. Either a CVR154 or CVR152
How would I wire that since the subwoofer box has just the red and black cable connector? I'm in class right now, but in about 45 minutes I'll go check because its in my car. Do you think the amp I have would work fine?
  • Who's Online   0 Members, 0 Anonymous, 1212 Guests (See full list)
