Rebel4055's Lumina build log. It's going to be junked!
one day you'll get loud haha
but untill then me n my buddy got a louder lumina haha
R.I.P!
(Nov-29-2009)
92 explorer
current build
I know this build looks like crap but I'm still in the process of neatening everything up, I'm removing the back seat to run the power wire better so it doesn't loop around in the trunk and the same goes for the RCA's.
If you guys want give me suggestions on what to do, I'm debating if I should try 2 15's or 2 12's like I originally planed. I'm getting a sweet deal on the 15's so I don't know.
I'm afraid that the 2 15's won't fit in without having the box built in the trunk.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
Here is a update to my plans.
I'm getting 1 or 2 CM Cast Mojo 15's. I'm going to run 1 in the trunk fired forward sealed from the trunk. I'll keep the other one just to have.
4.3 cubes tuned to 34hz.
uhoh_45 helped out a bunch since his buddy has basically the same lumina.
not bad not bad not that engines gotten some work on lets see some work on the audioz
R.I.P!
(Nov-29-2009)
92 explorer
current build
whats the sub going to be wired to?
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
