sonic purity Posted November 12, 2010 Report Posted November 12, 2010 I need it for subs haha. Pair of Boston Acoustics G312's or Image Dynamics IDQ 12"s Two reasons: I assume the amp is an a/b because its two channel and INHMO the a/b have better SQ than any mono block amp I have heard. The Boston and ID have a great mix of SQ and SPL and have the right power handling for the amplifier you have. There are lots of subs out there, so really it going to come down to how much you can afford, the boston is on the lower end and the ID is on the higher end. Choose what sounds good to you and dont look back n2caraudio.com
Guest Posted November 12, 2010 Report Posted November 12, 2010 they do have monoblock AB amps you know.
sonic purity Posted November 12, 2010 Report Posted November 12, 2010 He said it was a two channel amp. Not a mono n2caraudio.com
Ji553r Posted November 12, 2010 Report Posted November 12, 2010 He said it was a two channel amp. Not a mono there are 2 chan monoblocks I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
IH8PunkRok Posted November 12, 2010 Report Posted November 12, 2010 there are 2 chan monoblocks say what? does that even make sense? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
BassHead1990 Posted November 12, 2010 Report Posted November 12, 2010 they should call 2 channel amplifiers binoblock lol (2007 Chevy Tahoe LT) Mechman 320A OEM AGM D'Amore Engineering HLC-2 Sig Converter D'Amore Engineering E1500.1 Fi Audio Neo 3.5 12"
Ji553r Posted November 12, 2010 Report Posted November 12, 2010 say what? does that even make sense? nope not at all ill get you a link though hold on I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Guest Posted November 12, 2010 Report Posted November 12, 2010 He said it was a two channel amp. Not a mono *sigh*. he said he wants a 2 channel for SUBWOOFERS. why in gods mind would you want a 2 channel for a subwoofer, makes no sense.
Ji553r Posted November 12, 2010 Report Posted November 12, 2010 2 channel monoblock: http://www.sonicelectronix.com/item_23855_Soundstream+XXX-15000D+-XXX15000D-.html I don't fuck around. I go from zero to I hope you die in less than 2 posts build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
BassHead1990 Posted November 12, 2010 Report Posted November 12, 2010 maybe just a general idea?? two woofers, two channels.... (2007 Chevy Tahoe LT) Mechman 320A OEM AGM D'Amore Engineering HLC-2 Sig Converter D'Amore Engineering E1500.1 Fi Audio Neo 3.5 12"
