I have a couple questions about putting LED light bars in the interior of a vehicle. First do you have to use the lights that are set up for 12 volts if you are running them off of power from your amp? Also how do you wire like an led bar? I want to put a light bar back by my subs for at night and i was curious as how to do this. Also if i get a switch do i put that in line with the power wire?
2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012drew.png
no. this is for converting dc to ac. useful if you want to run a blender inside your car.
Yes you can put the switch in line with the power, or the ground. What other kind of LED bars were you planning on using besides 12v ones? I put a bunch of cheap flexible LED strips in my car wired to my dome light and they look good. I wouldnt make it so you can see the bar or strip, it makes it look ricey and stupid in my opinion. You can tap into anything that has power to it. Your amp power would work fine if you want the light back there.
Edited by micah_jones
Black 2008.5 Mazda 3s Touring 5 Speed Hatchback
Tinted tails/turn indicators, blacked out emblems, partially debadged, 20% tint all around,
Big 3 in Knu KLMX 1/0, LED footwells/interior lights
DECK: Kenwood DDX-512 double DIN touchscreen with backup camera
FRONT STAGE: Stock for now, yippy (Looking for something nice...)
FRONT STAGE AMP: Looking for something nice...
SUB: 15 inch DC level 4 with level 5 coil upgrade, red dustcap
SUB AMP: Audiopipe AP15001D at 1 ohm
WIRING: All Knukoncepts Kolossus/KCA wire
LEGAL TERMLAB SCORE: 135.8db at 42hz(pathetic, I know. I need a battery in the back,
dropping to 11.9v isnt cutting it.....)
I haz teh Term-Lab. PM me if you are close and want to get metered.
The reason that i asked about 12 volt ones was; I was looking on the internet and some said 12v and others did not. My plan was to either put it by my amp or under shining up towards my subs.
okay.. I am a noob at this.. so you would put one from your powersource, then one and ground it, and then the last attach the power wire of the light bar? also how would you go about attaching your wires to this? could you loop them through or solder them?
would this Switch work? And if so how would you wire it up?
Yessir. One prong is for ground, one prong is for the LED strip, and one prong is for a constant 12 volt source (battery)
Edit: Ninja'd
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Yep, that's how its wired. As for the 2nd question, I would solder
LMFAO so true
:blush:
alright, well i am thinking about going and picking this up for my weekend project, because i get out for thanksgiving break thurdsay. So any more advice?
  • Who's Online   0 Members, 0 Anonymous, 1945 Guests (See full list)
