if its a high output alt what most ppl dont no is they have a certain turn on rpm speed. the alt wont really start to kik in until u git the it up to that set rpm. im sure if u contact mechman theyl tell u the same thing but they can probly tell u what rpm it should start powering up. most likely its gonna be a higher rpm. but a smaller pulley on it should help u sum thow
I would think that an overdrive pulley would help it to kick in at idle at the least.. That's a bummer if not.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Alt is fucked, that is a ad244 series alt most likely all of the HO series ad244 series alt have a voltage set point of 14.9 cold. So if at idle you are not charging that high, regulator is done or the brush is not making good contact. But you said it does okay once you raise rpm, so I would say voltage regulator, contact mechman and have them fix it. That is one of the common components that can fail. No biggie.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Alt is messed up, regulator or bad brush contact.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 3082 Guests (See full list)
