Rebel4055 Posted November 14, 2010 Report Posted November 14, 2010 http://www.sonicelectronix.com/item_22635_Rockford+Fosgate+RF-BLD.html T That one to be specific. Now my HU doesn't have very good pre-outs only 2.2v so I want to get a line driver. Now will this one work out for me or should i get a different one? I don't want to dump 200 dollars on one tho. Also how would I wire this up? Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
n8ball2013 Posted November 14, 2010 Report Posted November 14, 2010 you are running 250 watts and worried abotu a line driver? What makes you think you need one. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Rebel4055 Posted November 14, 2010 Author Report Posted November 14, 2010 you are running 250 watts and worried abotu a line driver? What makes you think you need one. That 250w is about to look like a pebble in a bit! Going to be running 600-1000w. D: EDIT: Buying one of techforces amps. And also have to turn the amp gain really freaking high to get where I want it. Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
Guest Posted November 14, 2010 Report Posted November 14, 2010 I have 2v preouts and I only have to turn the gain on my audiopipe like 1/3 of the way up. You probably don't have the volume up high enough to get the headunit to output sufficient preout voltage
uhoh_45 Posted November 14, 2010 Report Posted November 14, 2010 just make sure when buying a line driver you get one that matches your amps impute voltage or is under it... dont wanna blow your imputes also look into a linedriver/3way xover R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
Rebel4055 Posted November 14, 2010 Author Report Posted November 14, 2010 Thanks for the replies! Kranny can you hop on chat real quick? Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
