KnockinthaStreetzof608 Posted November 14, 2010 Report Posted November 14, 2010 well i been looking at many build with the trunk is sealed, and many ppl used alot of different things expanding foam tape ect... so pretty much what im tryin to get at has anyone used Foil Insulation Tape from SS instead of gorrilla tape for sealing it off?? and if so is there much of a difference??? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
keepinitloud Posted November 14, 2010 Report Posted November 14, 2010 that would probably work give it a try 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
KnockinthaStreetzof608 Posted November 14, 2010 Author Report Posted November 14, 2010 that would probably work give it a try hey thanks man! Im definalty send me some pm's when i start more into the build, because im a complete noob at this, o and also u think its possible when bumping the subs have 1 seat up? just that if its not the one with the port?? idk if im making sense or not CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
Alex K Posted November 14, 2010 Report Posted November 14, 2010 Use foam tooo!! I have foam, tape, then deadner on my box to seal it off. Tape alone won't be as good as if there was foam too. 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
KnockinthaStreetzof608 Posted November 14, 2010 Author Report Posted November 14, 2010 Use foam tooo!! I have foam, tape, then deadner on my box to seal it off. Tape alone won't be as good as if there was foam too. yea, ofcourse i was planning on using expanding foam its just i dont how much yet, but i still dont have the box, im not really good at box building and espcially in my mustang its so small, the only thing i can think of to do is just to have it build inside the trunk CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
Alex K Posted November 14, 2010 Report Posted November 14, 2010 yea, ofcourse i was planning on using expanding foam its just i dont how much yet, but i still dont have the box, im not really good at box building and espcially in my mustang its so small, the only thing i can think of to do is just to have it build inside the trunk +1 tp building in the trunk Me too, next build! 2006 Nissan Z Track. My Feedback Thread i used to think a band pass was something you were around your neck or something.
keepinitloud Posted November 14, 2010 Report Posted November 14, 2010 yeah mustang trunks are notorious for being a pain in the butt for boxes so you will have better luck building in the trunk or tryin to squeeze in from the cab of the car and use foam lots of it and then if you want then use the tape 06 chrysler 300C Hemi one mmatts dreadnaut 15 powered by a planet audio vx 2200d fosgate p200 running planet audio 8" midbass drivers and super compression tweeters stock battery and a stinger spv44 Irragi 300 amp alternator big 3 1/0 http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
KnockinthaStreetzof608 Posted November 14, 2010 Author Report Posted November 14, 2010 yeah mustang trunks are notorious for being a pain in the butt for boxes so you will have better luck building in the trunk or tryin to squeeze in from the cab of the car and use foam lots of it and then if you want then use the tape the thing i think the cab is smaller then the trunk its like 12 or 11 " and like 38.5" arcoss CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
KnockinthaStreetzof608 Posted November 14, 2010 Author Report Posted November 14, 2010 +1 tp building in the trunk Me too, next build! what does tp mean? lol CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
