horndawg Posted November 17, 2010 Report Posted November 17, 2010 keep blowing inline fuse from battery going to 2 amps, only happens when i crank the volume up really loud. the fuse came with an amp kit so it may be a cheapie it is 100 amp... do i need to upgrade the inline fuse or what? cannot remember what the fuse ratings are for my amps but they are : boston acoustics gt28 and sundown audio 125.2
dugee81 Posted November 17, 2010 Report Posted November 17, 2010 yeah you are probably pulling more like 120-140 amps.. but i dont think that would blow your fuse. have you checked your grounds? 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
sqsux Posted November 17, 2010 Report Posted November 17, 2010 does it blow right away after you turn it up all the way? your amps are fused for almost double what your inline is, I would switch to a 200. Start out boxy, shape as you move along. Dc Audio Team Fur
Skullz Posted November 17, 2010 Report Posted November 17, 2010 Fuse the wire and not the amps as each amp will have its own fuses, here is a link to a wire calculator, just put in the size, length and volts and that will let you know what to fuse it at. Maximum current is the amount of amps that can run safely through the wire. http://bcae1.com/images/swfs/wirepowercalculator.swf 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Socky Posted November 17, 2010 Report Posted November 17, 2010 You need a bigger fuse, you so pulling more that 100 amps. Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
horndawg Posted November 17, 2010 Author Report Posted November 17, 2010 does it blow right away after you turn it up all the way? your amps are fused for almost double what your inline is, I would switch to a 200. yes, it blows the fuse right away when it is turned up and starts to rattle the windows. what kind of inline fuse would you recommend?
sqsux Posted November 17, 2010 Report Posted November 17, 2010 yes, it blows the fuse right away when it is turned up and starts to rattle the windows. what kind of inline fuse would you recommend? I would check to make sure there are no loose connections or cut wires before you upgrade, fuses can last up to 5 minutes when twice their rated current is pulled, and you're not pulling 200amps. http://www.amazon.com/Link-ANL150-150-Amp-Fuses/dp/B000P0UBPO get something like that, either 150 or 200 amp, check your wiring first though, if any of it is burnt or cut replace it or you'll be driving down the road in a ball of fire one day. Start out boxy, shape as you move along. Dc Audio Team Fur
horndawg Posted November 17, 2010 Author Report Posted November 17, 2010 what about those inline power circuit breakers? does anybody ever use them? seen it while i was browsing ebay for inline fuses...
kmalinich Posted November 17, 2010 Report Posted November 17, 2010 what about those inline power circuit breakers? does anybody ever use them? seen it while i was browsing ebay for inline fuses... They degrade in functionality each time they open the circuit. That's why we don't use them.
