hey guys im going to be using 3'' pvc ports for this next build and im wondering whats the best method for flaring the ends of the pipe?
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
i dont know whats "the best"
heat moulded pvc
but remember this
patience, trial and error is gonna need to happen
thanks i give that a try! anyone else had any experience with doing this?
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
3 inch should be pretty easy. My 6" wasn't too bad but was a bitch since it was only 50 degrees outside and cooked off to fast. I used a metal bowl that was just smaller then the pipe on the bottom so it barely fit over it. Heated the bowl up with a heat gun and then heated the shit out if the PVC till you could see it was soft and start pushing down with some strength while still applying heat. Helpful to have someone help. Keep pushing til it's flared to your liking and hold it there with strength until it cools. Then remove. And the more flare you get to the harder it is to push down.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
where would i get said metal bowl? lol
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
I did it with 6" tubes, 4 of them, i wanted to get bigger flares but couldn´t do it because they won´t fit, box is too thin, anyways, 3" should be pretty easy, here´s a vid i recorded doing them.
