voltage problems
I have a mechman 270 alt, xs 3400 under the hood and 2 big deka leded batts in back with a ap 3000 rms amp, and my at full tilt my amp says it is only seeing 11.2 volts but when I have the volt meter to my front batt it is 13.9 at full tilt, my ground is ran all the way up to the front batt, any help would be great on why my amp is not getting full voltage
what is the voltage at the back battery? what size is your wire?
and the dekas are lead acid batteries?
why a 250? Are you using Copper clad aluminum wire?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
OFC is capable of 300 amps of current carry. You have a 270 amp alternator as well that is probably underrated. Are you at idle when you are testing this drop? If so you are probably only getting about 130 amps produced. a real 3kw amp should pull about 350 amps of current. how old are your batts in the reaer
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
