My system used to hum at 0 volume. what normally causes this RCAs?
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
Bad headunit ground maybe
(2) Kicker L5 12's
Alpine IDA-X305 HU
Dual Optimas
Big three
Kenwood EQ
RF Components
Hifonics Brutus 1K (Subs)
Alpine MRP 250 (Mids/Highs)
Lots o' sound deadening
Bad Install shops.
Power wire ran on the same side as RCA's.
you arent even right dont try to look like you know what you are talking about.
its a bad ground. Can you get ground noise from RCAS too close to power wire? yes but I'll bet you I can take a pair of quality RCAs and run it down the same side as my power and be just fine.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
oh ok, I had the ground to my seat bracket cause i could think of anywhere else to put it, unless i drill a hole throw the floor and mount it somewhere there or run a ground to my battery
Mechman 320A
OEM AGM
and thats why you have ground noise ill bet.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
where would be a good ground?
Mechman 320A
OEM AGM
make your own on a paint free solid metal surface. or run to the battery
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Sorry man.. You don't have to be mean all the time.
That's just what had happened to me
You can also get humming and engine noise from cheap spark plug wires.
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Infiniti Kappa 3.5's and 6x8's
Bravox 6.5 components
  • Who's Online   0 Members, 0 Anonymous, 1187 Guests (See full list)
