rasic Posted November 23, 2010 Report Posted November 23, 2010 So I put in the other 12 and the sound cuta out at 24 out of 31 stock head unit in this car. It wouldn't do that with only 1 12 could it be the voltage drop? Or the shit head unit system: changes way to much...
Hugh G. Rection Posted November 23, 2010 Report Posted November 23, 2010 So I put in the other 12 and the sound cuta out at 24 out of 31 stock head unit in this car. It wouldn't do that with only 1 12 could it be the voltage drop? Or the shit head unit need...... more....... info.......... Owner of BigAss Ports
rasic Posted November 23, 2010 Author Report Posted November 23, 2010 What else is needed my info is in the sig. system: changes way to much...
Sanitarium Posted November 24, 2010 Report Posted November 24, 2010 how do you have those 2 d2 subs wired? cause it's likely you wired them down to 0.5 ohm and it's putting your amp into protect.
slamin87 Posted November 24, 2010 Report Posted November 24, 2010 eigher your battery voltage dropin so bad its puting the amp in protection mode or you have them wired lower then what the amp can handle so it gos protective mode or your rca are bad need more info how they cutting out what it doin cuting out when you turn it up our?????????
rasic Posted November 24, 2010 Author Report Posted November 24, 2010 I don't understand a word you said. Its wired to 2 ohms and I've checked all connections. The amp isn't going into protect cause its not hot or clipping and when I turn it one volume down it wont do it. It usually happens on higher frequencies system: changes way to much...
Hugh G. Rection Posted November 24, 2010 Report Posted November 24, 2010 eigher your battery voltage dropin so bad its puting the amp in protection mode or you have them wired lower then what the amp can handle so it gos protective mode or your rca are bad need more info how they cutting out what it doin cuting out when you turn it up our????????? whoa........ you have officially killed the english language. Owner of BigAss Ports
fecupe2001 Posted November 24, 2010 Report Posted November 24, 2010 Say what? i hope your primary language isn´t english!! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
rasic Posted November 25, 2010 Author Report Posted November 25, 2010 im guessing its the voltage drop and the headunit since no one knows what it is system: changes way to much...
