DC Sound Lab
4 XL 15s and a Warhorse 1/23 TL?????
[quote name=dwright27' date='23 January 2011 - 05:41 PM' timestamp='1295826061'
post='1367367]
Sure you will ^^^
Ha I aint got much of a choice. I
havent exactly taken the best care of these wheels and I need new tires, so I figure I might as well upgrade to some 6s
Fixed for you!!
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
post='1367367]
Sure you will ^^^
Fixed for you!!
Nope no 6s for me! My truck already rides rough with the 265/40/22 tires I have. I want to have as much rubber as I can fit to help with the ride. 24s should do nicely
post='1367367]
Sure you will ^^^
Fixed for you!!
I'm wanting some 8s now to be honest.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
I just looked at the cost for tires for 24s an it makes me like my 22s just fine
Oh come on, they aren't that bad
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
What sizes will fit my 2006 Ford F150 XLT Super Crew 2wd ? Select New Vehicle
Applicable sizes are marked with a blue dot ( ).
PriceSizeServ. Desc.
235/55R17 99V Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “V” = 149mph (240kph) $150.00 (ea.)
235/60R17 102V Load Index 102 = 1874lbs (850kg) per tire
Speed Rating “V” = 149mph (240kph) $156.00 (ea.)
235/65R17 104H Load Index 104 = 1984lbs (900kg) per tire
Speed Rating “H” = 130mph (210kph) $140.00 (ea.)
255/55R17 104V Load Index 104 = 1984lbs (900kg) per tire
Speed Rating “V” = 149mph (240kph) $210.00 (ea.)
275/55R17 109V Load Index 109 = 2271lbs (1030kg) per tire
Speed Rating “V” = 149mph (240kph) $149.00 (ea.)
235/50R18 97V Load Index 97 = 1609lbs (730kg) per tire
235/50R18 97H Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “H” = 130mph (210kph) $215.00 (ea.)
235/60R18 103H Load Index 103 = 1929lbs (875kg) per tire
Speed Rating “H” = 130mph (210kph) $197.00 (ea.)
255/55R18 109V Load Index 109 = 2271lbs (1030kg) per tire
Speed Rating “V” = 149mph (240kph) $197.00 (ea.)
255/55R18 109H Load Index 109 = 2271lbs (1030kg) per tire
Speed Rating “H” = 130mph (210kph) $189.00 (ea.)
285/50ZR18 109W Load Index 109 = 2271lbs (1030kg) per tire
Speed Rating “W” = 168mph (270kph) $202.00 (ea.)
235/45R19 99V Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “V” = 149mph (240kph) $199.00 (ea.)
235/55R19 105V Load Index 105 = 2039lbs (925kg) per tire
Speed Rating “V” = 149mph (240kph) $247.00 (ea.)
255/50R19 103W Load Index 103 = 1929lbs (875kg) per tire
Speed Rating “W” = 168mph (270kph) $208.00 (ea.)
255/50ZR19 107Y Load Index 107 = 2149lbs (975kg) per tire
Speed Rating “Y” = 186mph (300kph) $277.00 (ea.)
265/50R19 110V Load Index 110 = 2337lbs (1060kg) per tire
Speed Rating “V” = 149mph (240kph) $259.00 (ea.)
275/45R19 108V Load Index 108 = 2205lbs (1000kg) per tire
285/45ZR19 107W Load Index 107 = 2149lbs (975kg) per tire
Speed Rating “W” = 168mph (270kph) $237.00 (ea.)
235/45R20 100H Load Index 100 = 1764lbs (800kg) per tire
Speed Rating “H” = 130mph (210kph) $152.00 (ea.)
255/45R20 105V Load Index 105 = 2039lbs (925kg) per tire
Speed Rating “V” = 149mph (240kph) $248.00 (ea.)
265/45R20 108H Load Index 108 = 2205lbs (1000kg) per tire
Speed Rating “H” = 130mph (210kph) $163.00 (ea.)
275/40ZR20 106Y Load Index 106 = 2094lbs (950kg) per tire
Speed Rating “Y” = 186mph (300kph) $367.00 (ea.)
275/45R20 110H Load Index 110 = 2337lbs (1060kg) per tire
Speed Rating “H” = 130mph (210kph) $260.00 (ea.)
295/45R20 110V Load Index 110 = 2337lbs (1060kg) per tire
Speed Rating “V” = 149mph (240kph) $190.00 (ea.)
305/45R20 112V Load Index 112 = 2484lbs (1129kg) per tire
Speed Rating “V” = 149mph (240kph) $273.00 (ea.)
265/35ZR22 102W Load Index 102 = 1874lbs (850kg) per tire
Speed Rating “W” = 168mph (270kph) $206.00 (ea.)
265/40R22 105W Load Index 105 = 2039lbs (925kg) per tire
Speed Rating “W” = 168mph (270kph) $242.00 (ea.)
275/45R22 112V Load Index 112 = 2484lbs (1129kg) per tire
Speed Rating “V” = 149mph (240kph) $180.00 (ea.)
285/35ZR22 106W Load Index 106 = 2094lbs (950kg) per tire
Speed Rating “W” = 168mph (270kph) $222.00 (ea.)
295/30ZR22 103W Load Index 103 = 1929lbs (875kg) per tire
305/35ZR22 110W Load Index 110 = 2337lbs (1060kg) per tire
Speed Rating “W” = 168mph (270kph) $305.00 (ea.)
305/40ZR22 114W Load Index 114 = 2640lbs (1200kg) per tire
Speed Rating “W” = 168mph (270kph) $292.00 (ea.)
285/35ZR24 108W Load Index 108 = 2205lbs (1000kg) per tire
Speed Rating “W” = 168mph (270kph) $311.00 (ea.)
295/40ZR24 114W Load Index 114 = 2640lbs (1200kg) per tire
Speed Rating “W” = 168mph (270kph) $295.00 (ea.)
305/35ZR24 112W Load Index 112 = 2484lbs (1129kg) per tire
Speed Rating “W” = 168mph (270kph) $342.00 (ea.)
385/35R24 116W Load Index 116 = 2806lbs (1275kg) per tire
Speed Rating “W” = 168mph (270kph) $334.00 (ea.)
315/40R25 120V Load Index 120 = 3169lbs (1440kg) per tire
Speed Rating “V” = 149mph (240kph) $469.00 (ea.)
295/25ZR26 102W Load Index 102 = 1874lbs (850kg) per tire
Speed Rating “W” = 168mph (270kph) $395.00 (ea.)
295/30R26 107W Load Index 107 = 2149lbs (975kg) per tire
Speed Rating “W” = 168mph (270kph) $399.00 (ea.)
305/30R26 109V Load Index 109 = 2271lbs (1030kg) per tire
Speed Rating “V” = 149mph (240kph) $382.00 (ea.)
315/40R26 120V Load Index 120 = 3169lbs (1440kg) per tire
Speed Rating “V” = 149mph (240kph) $345.00 (ea.)
295/25R28 103V Load Index 103 = 1929lbs (875kg) per tire
Speed Rating “V” = 149mph (240kph) $679.00 (ea.)
325/35R28 120V Load Index 120 = 3169lbs (1440kg) per tire
Speed Rating “V” = 149mph (240kph) $623.00 (ea.)
315/30R30 114V Load Index 114 = 2640lbs (1200kg) per tire
Speed Rating “V” = 149mph (240kph) $1,068.00 (ea.)
That price is for pirelli Scorpion Zero 24s vs $180 for 22s
Why do you need pirellis?
Tires for my 6s are only $250 iirc and they ride pretty good is it is, 305/30/26.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Yea my tires do stick out a good bit at the bottom where the fenders flare back toward the frame.
Desbt bother me to much though.
I'm Just giving you a hard time is all lol.
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
  • Who's Online   0 Members, 0 Anonymous, 1258 Guests (See full list)
