Sir-Lancelot's Yukon XL Build
Hey guys. Don't post much on here, mainly on SSA. Have enjoyed looking around and thought I would post up my build for others see.
I am not finished and still have some tweaking to do so I will update on here as I progress. I hope you like it.
Feel free to post up comments, good and bad are welcome.
This was not meant to be a numbers build. I drive this every day and being musical was a top priority. I can appreciate all the time and effort that it takes to pull off a SPL builds, but that was not MY goal. I wanted a loud ground pounder that would allow me to go to some shows and have fun with it, but still sound damn good on music.
List of the goodies
Headunit:
Clarion DXZ785USB
Front:
B&C 10NW64 10" Neodymium Woofer
Crescendo XST2
Rear:
B&C 8NDL51 8" Neodymium Woofer
Crescendo XST2
Mids & Highs amps
MB Quart DSC 4125 bridged to the mids
MB Quart DSC 480 bridged to the tweeters
Subs
4 18" XCONS
Enclosure
26cf @ 33hz 341" port
Sub Amps
2 Crunch GP3000D's strapped
Electrical
Iraggi 260 Amputator, * dual alternator bracket/2nd alternator set up from tejcurrent on order
4 Kinetik HC2400
2 runs of 0/1
Picture of the victim.
Started glassing the front doors
The plan
Getting started
Almost done, need to fill some low spots and sand a little more.
On the door
With drivers
The pods
With drivers
Loaded
On the door
Covered the pods in vinyl. I usually paint, but wanted to try something new. Vinyl is a bitch and this will be my last time messing with it. Paint FTW! LOL
2001 Yukon XL
Sitting on 35 x 12.50 x 20, XD Monsters
Headunit: Clarion DXZ785USB
Front: B&C 10NW64 10" Neodymium Woofer, Crescendo XST2
Rear: B&C 8NDL51 8" Neodymium Woofer, Crescendo XST2
Mids & Highs Amps: MB Quart DSC 4125, MB Quart DSC 480
Subs: 4 18" SSA ZCONS
Sub Amps: 4 GP3K Pro
Electrical: Iraggi 260a, 3 tejcurrent 240a, tejcurrent quad bracket
Kinetik - 6 HC2400
My Build Log
Quick pic of the Clarion. Poor thing is so ugly, but damn it's a great HU for the money.
Big Ass Hole here
Didnt have a good way to bolt the pod to the door, so had to improvise. Cut some steel and bolted it to the door with lock nuts.
Sealed it up.
The front pods are bolted directly to the door and vent through the factory speaker opening. I used 6 bolts per side, they aint going no where.
2001 Yukon XL
Kinetik - 6 HC2400
My Build Log
On to the rear
Box
Starting to cut the bracing, yes I am old school and use a jig saw. Maybe one day I will get a router, but I do pretty good with this if i must say so myself.
High speed, coarse blade, and go SLOW = Nice results.
2001 Yukon XL
Kinetik - 6 HC2400
My Build Log
im liking this thus far :)
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
All the port and bracing cut !
2001 Yukon XL
Kinetik - 6 HC2400
My Build Log
The right corner got scratch up moving it from the porch to the truck and that sucks, but I ain't redoing it.
Might try to use some vinyl repair from the parts store to see if i can make it look a little better. :puzzled:
Anyone got any other ideas.
For some nighttime fun, wired some LED's in the box. My buddy said it looks like a fish tank. I agree. lol
With the inside painted white it changed to glow to a aqua instead of a blue. I like it better. I had some help with the lights and have to give a shout out to my friend Sefugi.
Thank you for all your help, it turned out better than I expected.
Pics of the subs :wub:
Some pics: Let me know what you think.
2001 Yukon XL
Kinetik - 6 HC2400
My Build Log
Some daytime shots of the box
I took some pics of the new 35w 3000k fog lights I put in this week. I have 55w 5000k in high and low beams. Highs and lows both stay on when the highs are on.
They are bright as shit with the four on at the same time.
High beams. :ohnoes9:
2001 Yukon XL
Kinetik - 6 HC2400
My Build Log
Also, I put a blue 5mm LED light in each of the 6 overhead air vents. They are on a different switch than the LED's in the box.
2001 Yukon XL
Kinetik - 6 HC2400
My Build Log
Fastest build ever.
:lol:
2001 Yukon XL
Kinetik - 6 HC2400
My Build Log
