bass_stalker Posted November 29, 2010 Report Posted November 29, 2010 would two square kicker 10's require more airspace than a traditional round 10. i am thinking of buying the square 10's but i dont know if i could build a box with enough airspace that will still fit under the back seat in an extended cab silverado. also would square 10s hit harder than regular 10s or 12s JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
SleeperSierra Posted November 29, 2010 Report Posted November 29, 2010 the L7/L5 10 needs .66Cu after woofer displacement Comp 10 1Cu after WD CompVx is .8Cu after Wd CompVt is .8Cu after Wd take a pen and paper and tape measure and go measure the space under your backseat, then put those numbers into a box calculator and see if you do in fact have the space, ive never heard a L5/L7 10 play but the comps do well in the right box. .ılı.——Volume——.ılı. ▄ █ ▄ █ ▄ ▄ █ ▄ █ ▄ █ Min- – – – – – – – -●Max
TeamHT Posted November 29, 2010 Report Posted November 29, 2010 any differences are not going to be noticeable. obviously with a square youre looking at more cone area. a square 10" sub will have more cone than a traditional round sub. its been said to also offer a better frequency response, but none of my experiences have come to this conclusion. enclosures should be designed and built to the subs specs within your given space. hit harder? lol, once again. it depends on many factors including proper power application, vehicle, and enclosure. a square sub is not going to require so much more airspace than a traditional round subwoofer of the same diameter, lol. just PM BCPballer64, give him your subwoofer specs, max dimensions and see if a proper enclosure can be built within the space. i dont like the way square subs look in my opinion. Tell me...does this smell like chloroform to you?
bass_stalker Posted December 2, 2010 Author Report Posted December 2, 2010 thanks for the info guys. i really appreciate it JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
