As posted awhile back I bought my brothers subs and amp, he bought (and was using) the exact same HU that I have, but the bass was really good in his car with bass boost on the amp all the way off and when I hooked them up to my car you could hear almost nothing even with the volume all the way up and your head right by the subs. I had to put bass boost all the way up for it to actually hit and I can tell its really wearing on them now so what could the problem be?
Subs are 2 12" Xplode and the amp is a Kenwood KAC-8105d
EDIT: He said he didnt mess with any of the amp controls either
Edited by Velvetdreams21
1993 Cadillac Fleetwood Brougham.
Jensen UV10 DVD HU
Two 12" Sony Xplode (temporary)
check your rca connections as well as at the headunit need to know what kind of head unit is it hooked to the sub out? does your head unit have some sort of bass gain?
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Its the Jensen UV10 dvd HU. Its hooked to the normal amp out (unsure what to do for the sub out since its only one rca). It does have bass gain but IIRC its not much and since my dad messed up on the box I cant access my screen to adjust that.
How are the subs wired?
In a way I dont understand and I think isnt right at all but the guy at best buy wired it and my brothers friend (who apparently knows a lot about car audio) said its the way he would have wired it. The amp speaker wire goes to one sub, and then a second wire goes from that sub to the other.
Jensen UV10 DVD HU
lol wait a second wire? just one or actually a piece of speaker wire that has 2 conductors a pos and neg? also check the phase of your woofers it sounds like you have a phase issue. pop your speakers with a cordless drill battery to make sure they are botrh moving outward. also use a rca y adapter on your sub out
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Nooo, its a second speaker wire haha.
What do you mean pop my speakers? Im still learning.
Do you think going from the normal amp out to the sub out would really make that much of a difference? Btw, I know for a fact his wasnt on the sub out but Id be willing to do it of course.
Jensen UV10 DVD HU
I'm pretty sure the only difference is the head unit control for the sub.
Other than than that, the amp takes a signal from anything you hook up to it and if you notice, it has a frequency range which also picks up voices if you set it high enough
I had my amp hooked up to the rear outs and now it's on the sub out. sounds the same.
tl;dr if your head unit has sub control you're going to want it on the sub pre-out. heck, just hook it up right...
i suck men dry...email me for details
Well whenever I can find someone to build me a box for my stereo I will be able to do that, need the screen to set it up
Jensen UV10 DVD HU
You really should check your wiring. First the grounds and rcas. Then the wiring under the hood, power, and ground to the amp. Then the subwoofer wiring. What are the voicecoil configurations of the subs?
Well I will admit I need to make a better ground connection just havent had the time due to weather, work etc.
And honestly, I have no idea what the configurations are/how to find them
Jensen UV10 DVD HU
  • Who's Online   0 Members, 0 Anonymous, 1991 Guests (See full list)
