Need help with port. box is almost done
I'm almost done building a 2.58 cube box for my 2 12 in ssa d cons. The last thing I'm stuck on is the ports. I have it set up for dual 4 in aero ports. I cant find a calculator that says how long they need to be each. I found one on carstereo and it came up with 19.78 but didn't say if that was each or divided between them.
Does anyone know? I'll try to post up a build log when I'm done.
Torres calculator works awesome, you can find it on a sticky post in here, but, if the calculator said it needs to be 19.78" then it´s EACH tube, that´s one small box actually, i wouldn´t try to tune it very low, i would get something like 18" each tube so you end up around 2.3 cubic feet and 38 hz tuning.
I know the box is small but thats as big as I can go in my 97 convertable mustang. I already have to partially build it in the trunk.
Do you think those subs would sound good ported at 38 hz? Their recommended for a little bigger box than I can provide but said to tune between 30-34 hz.
And I'm thinking of flaring the ports which says to add another inch onto the port. Would it be worth flaring it? I'm not worried about numbers I doubt I'll even ever run it on a meter I just don't want port noise.
Well, for around 2.3 cubic feet 2 4" ports it´s more than enough IMO, i don´t think you´ll have ANY port noise with that, i would use PVC tubes and start playing the system, if it has port noise then you can always flare the pvc or buy original aeroports if you want to spend the money on them, about the tuning, yes i do think it should sound very nice, with that little box even tuning it at 25 hz i don´t think you´ll be able to play the lows strong, that´s why i´m suggesting you to tune it around 38 hz, but i might be wrong, so who knows? there´s always different opinions on this forum hehe.
You are welcome hommie, one again, i would try different port lenghts until you find the one that sounds better to your ear, pvc 4" is cheap as hell!!!! :pardon:
  • Who's Online   0 Members, 0 Anonymous, 1559 Guests (See full list)
