Can def see a rebuid on this real soon, no way that particle board is gonna hold, it looks good though
aiit aiit well if i got another layer of particle board over it is getting that ontop.. and bracing from top to bottom..
after that i can only hope 4 the best until i get money to mdf
How much is MDF where you are? here its only 30 bucks for a 4x8 and i can see you getting away with a sheet and a half maybe? if it takes that much. Using a double baffle may require the 2nd sheet
Here its 89,50 for a 22x1220x2440 mm / 4x8 feet.
and i used 2 of those to this.. tho in particle board and thats about 40 each.
Is that US dollars?
the particle board will breathe too. the port being in the middle will add some structure but a double baffle really is needed. when you add bracing you want to use something round. air will flow around it better.
Is that US dollars?
Yes its U$D
Breath how?
ok ill c what i can get thats round then :D
fiberglass isnt cheap. itll cost as much if not plenty more than an extra sheet of wood to give the same strength. im not exactly sure as your prices seem pretty over the top.
particle board lets air through it. its a small amount but if you were to seal it with fiberglass resin, it would stop it.
you could use dowl rods for bracing and resin the inside of the box
head unit - pioneer DEH-P5100UB
subwoofer - nothing
speakers - powerbass components
amp - nothing
hmmm yeah true might be just better off buying mdf. i was looking at the sealing part of it as well. and i think i just got a deal on an ass ton of matting a while ago (haven't needed to buy any for a couple years haha) so i look at it differently. but the resin is the expensive part. also hard to tell where he's living as far as prices are concerned
but say you loved the output of your box, you could invest in some matting and resin and not have to rebuild. strengthen it a bit and seal it. but then again building/rebuilding is the fun part :)
dowels will help brace it, but resin alone won't help strengthen it. just help seal it
