dont bother with capacitors unless you have absolutely ZERO voltage drop. otherwise its just another thing stressing your alternator.
save the money and get a nice small battery
take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey
1998 Chevy Venture "Swagger Wagon"
Kenwood Excelon KDC-X994 Headunit
3 15" Alpine Type R's in seperate T-Lines
1 RF T1500-1bd for 2 of the 15s
1 RF P1000-1bd for the single 15
3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage)
1 Hifonics HFi100.4 4-channel amp
Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this)
Stock battery and one Optima Redtop for now (looking at XS batteries)
3 15" Alpine Type R's (aka Swagger Wagon Build 1.0)
Swagger Wagon Build 2.0
Youtube Videos
so when my bass hits and my headlights dim. is that an effect of a voltage drop?
yes! im sure you could find a kinetik hc600 or the similar shuriken for about as much as a cap!
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
yes....power is being taken away from the headlights....or your headlights are really loose :peepwall:
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Do the big 3 before that cap. If you are getting very little drop and dimming the simple big 3 could probably fix that issue.
i was thinkin about doing that. does it really make that big of a diiference?
and the hc600. whats its rating?
Kinetik HC600 Power Cell
"600 Watts, 12 Volt High Current Power Cell"
More powerful than 100 1 farad caps! Extreme power in a small package. Mount near your amplifier for tons of power reinforcement. Easily starts a V8 engine!
Specifications
* Weight: 14lbs
* Ah: 20
* Dimensions: 7"x3"x6.5"
* Suggested Retail: $199.99
Common Specifications
* AGM Technology
* Sealed Non-Spillable Design
* Mount In Any Position
* Ultra Low ESR
* More Plates For Stronger Energy Density
* Higher Voltage Under Load
* Tightly Packed Cells
* Superior Heat & Vibration Resistance
and yes Big 3 brings down resistance between your alt and batteries, allowing for easier current flow n whatnot!
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
