AMI CUSTOMS Posted December 15, 2010 Report Posted December 15, 2010 I would do the 3500 on all four. If you keep voltage up on that amp it makes lots of power, well over 4k no problem. And if you did the strapped option, you would set one amp to master and one to slave, there is a diagram that they send with the amp that shows what to do, pretty easy to follow. And you would need a final ohm of 2 ohms to be stable. That means that since they are in a master/slave linked config, each amp will "see" half the final ohm. So at 2 ohm each amp will "see" 1 ohm, making max power, to some degree, but due to imp rise, you will not likely see max power until you get a little under 1 ohm, I have personally seen the 3500's do well over max power when the amp "saw" .7 ohm but was wired at .25 ohm. ok one last thing is confusing me though does each amp need to see a two ohm load then put one of em in master mode and the other on slave and then each amp will half the final ohm load to 1 ohm? or say wire all 2/4 subs to 2 ohm and only plug it into one amp? When the two amps are strapped, you are connecting across both amps, so they are both connected to the subs. You need a final ohm of 2 ohms, and YES, set one on master and one on slave, each amp will see half the ohm load, so 1 ohm each. This happens because the manner of how they are linked, if I had a diagram it would be alot easier for you to see what I am talking about, but the way you wire the speaker terminals in a linked pair is a little different then just hook the + wire to the + terminal and so on... TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
RickyFriery97 Posted December 15, 2010 Author Report Posted December 15, 2010 I would do the 3500 on all four. If you keep voltage up on that amp it makes lots of power, well over 4k no problem. And if you did the strapped option, you would set one amp to master and one to slave, there is a diagram that they send with the amp that shows what to do, pretty easy to follow. And you would need a final ohm of 2 ohms to be stable. That means that since they are in a master/slave linked config, each amp will "see" half the final ohm. So at 2 ohm each amp will "see" 1 ohm, making max power, to some degree, but due to imp rise, you will not likely see max power until you get a little under 1 ohm, I have personally seen the 3500's do well over max power when the amp "saw" .7 ohm but was wired at .25 ohm. ok one last thing is confusing me though does each amp need to see a two ohm load then put one of em in master mode and the other on slave and then each amp will half the final ohm load to 1 ohm? or say wire all 2/4 subs to 2 ohm and only plug it into one amp? When the two amps are strapped, you are connecting across both amps, so they are both connected to the subs. You need a final ohm of 2 ohms, and YES, set one on master and one on slave, each amp will see half the ohm load, so 1 ohm each. This happens because the manner of how they are linked, if I had a diagram it would be alot easier for you to see what I am talking about, but the way you wire the speaker terminals in a linked pair is a little different then just hook the + wire to the + terminal and so on... would it be the same as sundown amps?? connect both negatives together with 8 awg wire then the slave gets the negative load and the master gets the positive load? 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
AMI CUSTOMS Posted December 15, 2010 Report Posted December 15, 2010 Yes just like that. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
RickyFriery97 Posted December 15, 2010 Author Report Posted December 15, 2010 Yes just like that. alright cool thanks for all your help man 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
