yea i know i was leading points in st 5 meca too. im going to see if i can compete in s5 for st finals and go back to 12v one time with some big surprises and finish the year with a bang! Im goin to focus on park an pound thats what a groundpounder is anyways.I love my 14v batts and the power i have now
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
not only were you points leader but score leader as well. it would be sad to see you not take it
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Took 2 -1sts at meca yesterday burped a 155.2 @37hz in mod5 and did a 134.3 in park an pound. heres a vid of my second run .i was trying to beat my first score but was down .1 it was hot, and my idle dropped. I have to figure out a way to keep my idle up under load.any ideas? i have a throttle cable i lock at 2000rpm but it loads down to 700 when the bass hits
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Looks good Ray. You've been talking about a C pillar wall for a while now. I say you'd be hard pressed to get much louder with the same cone area and power. But hey, you never know till you try.
ive been researching alot on walling it. and i dont think i will see that big of a gain with the same equipment.so my plan is to updrade subs and amps with current box to see what shes got. Dc M2s and 2-9ks
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I say the subs you got are badass. What about 6 18" lvl 4xls and 2, possibly 3 9ks?
I dont want to give up my back seat. i think my box is capable of 57s 58s eith more power and if needed some new DCm2s. Heres a number i did yesterday just trying a few tricks and after 7 burps. im pretty sure a 56 is right around the corner.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
