Impedance rise vs wire thickness
It's more than tuning. Pretty much every aspect of the box has some sort of effect on it. ft^3 of the box, port size, port length, tuning, how far the sub is from the port, etc etc etc. The only way we really know how to do anything about it right now is to build one box, clamp it and figure out your rise. Then build a few more boxes and clamp it to figure out the rise of those. Basically rebuild and rebuild and rebuild until you find what works best for you. And the box with the least rise may not end up with the highest TL score or sound the best, but it will be recieving the most power.
And that is kind of what I do, I use the imp rise to my advantage so I can get the most out of my amp on burp, which in turn with the proper freq and volume will yield the highest score.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
It just sucks that even if you change one aspect of the same box, it's going to change multiple aspects at the same time lmao. Like for your wall, if you were to lay down 1 layer of bricks on the inside you would reduce the air space, raise the tuning, and increase the in^2/ft^3 all at the same time.
And raise the rise at the same time. But I could reduce rise by just sanding the whole inside and resin it. LOL
Evo X build log
But I don't want to change my rise it is perfect right now. :peepwall:
Evo X build log
So you've found out the normally decreasing box space and raising tuning will also raise box rise? Interesting. I have a friend that was wiring his Stetsom 10k @ .5 ohms and rising to 2 ohms (4:1) and then wiring it at 2 ohms and rising to 4 ohms (2:1), one of the local guru's was saying how normally the lower you wire to begin with the lower riser you'll see and this setup deviated from what he normally saw.
See this is where I think the mech properties of the driver come into play, cuz in my setup, wired at 2, I rise to 6.5 (3.25:1) and wired at .5, rise to 1.4 (2.8:1), now if I put different 15's in my wall, like dc lvl 4 xl's dual 1's, will my rise be the same? That is what gets my mind going on this subject. Just change the woofer and see what happens. And assume the woofer has the same displacement so the box volume doesn't change obviously.
Evo X build log
Yea I was going to say the drivers will probably have different displacements, may not make too much of a difference but it will make some. I've only clamped my SMD wired at 1 (well .7 I guess) and I'm at 3.3 after rise, so that's about 4.7:1 unless you are just supposed to consider it 1 ohm then it would be 3.3:1. Don't feel like trying to wire it at 4 ohms and clamping the amp, I'm not that worried about rise lmao. Was just interesting to see the actual power I was getting out of my SAZ 4500.
Actually if you're that interested, I do have my friends BTL but it's a D1 vs my SMD which is D2 so that's 2 variables. I guess I could wire 1 coil of the SMD vs the BTL wired in series so they'll both be 2 ohms, do you think that would work?
No, that won't work, you don't want to ever wire just one coil on a dvc sub.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
