which batteries would work for me?
I have a 08 impala with a stock alt and the big 3 done running a aq2200 at 1ohm and the aq4 4ch at 4ohms. I don't know what my voltage is sitting at or what it drops to yet but I want to get a meter soon. What batteries would work under my hood and in the back? This battery and electrical stuff gets confusing
http://www.dcsoundlab.com/
2008 Chevy Impala (Daily Driver)
Pioneer touchscreen w/navi
1 DC XL 15" (around 4cuft ported box)
1 AQ2200
1 AQ90x4
Memphis MClass 6.5s (front doors)
Memphis MClass 6x9s (rear deck)
stock alt & front batt; 1 Red top in the trunk
139.2db sealed (on my old JL1000/1)
140.0db outlaw (on my old JL1000/1)
1992 Chevy S-10 Ext cab. (project car)
Coming Soon: Bagged with some kind of wall.
Have you measured up your stock battery location under the hood? To get the most of your money and performance, try to get a battery that is close to the stock battery/location size. For a trunk battery, as for Kinetik an HC2400 would do great, or as for XS Power prolly a D1200 or larger. There are more brands out there, just two for reference.
RF T600-4
RF T1500-1BDCP
FI BL 15
Iraggi 190A Alternator
Big 3
Kinetik HC1800
Kinetik HC2400
Knu Flex 1/0
2 Sets of RF T2 Component 6.5's
Own but not installed...yet
1 Set of RF T2 Component 6.5's
1 Set of Qlogic Kickpanels
Yeah I measured under my hood and its a tight area to work in and only the xs power d1200 will fit and I think the kinetik 1200 too
1 AQ2200
1 AQ90x4
Is check out the XS S1200 and if your electrical is wired still using the stock charging system...shouldn't you already have a stock voltage meter in the cluster?
From the equipment you're running, I wouldn't run it off of stock electrical, you could be seeing some steep drops.
  • 3 months later...
No my car just has a tach, speedo, fuel, and temp gauges :(
1 AQ2200
1 AQ90x4
  • Who's Online   0 Members, 0 Anonymous, 1258 Guests (See full list)
