im planing on building a desent system with one 18" fi fbl. i dont knw what amp to use or the sq.ft on the box. can someone help?????
N218
DUAL 1 | DUAL 2
Fs: 34.0 Hz | 33.6 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 8.18 | 8.28
Qes: .32 | .32
Qts: .31 | .31
Mms: 336g | 344g
Sd: 1210cm^2 | 1210cm^2
Vas: 133.8 l | 133.8 l
Spl: 94.0dB 1W/1m | 93.8dB 1W/1m
Bl: 17.8 N/A | 25.1 N/A
Xmax: 28mm * | 28mm *
Rms: 2000W * | 2000W * <-get an amp with this number
Sealed box: N/A cuft | N/A cuft
Ported box: 4.5-8.0cuft | 4.5-8.0cuft <-get a box with this volume
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 11.125” | 11.125”
Displacement: 0.18cuft | 0.18cuft
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
N218
DUAL 1 | DUAL 2
Qms: 8.18 | 8.28
Qes: .32 | .32
Qts: .31 | .31
Mms: 336g | 344g
i likememphis car audio amps but who else has good amps and not so high price? so the cut has to be within 4.5 and 8cuft what would be better to stay closer to 4.5 or 6cuft or 8cuft?
I like memphis car audio amps but who else has good amps and not so high price? So the cut has to be within 4.5 and 8 cuft what would be better, to stay closer to 4.5 cuft or 6 cuft or 8 cuft?
AQ has some great amps, so does Crescendo, but they are sold out at the moment. Or you could get some secondhand Atomic or Sundown (or new depending on your budget)
It depends how much power you are going to send to it, since you are sending it rated power (most likely), 6.5-8 should be fine.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
  • Who's Online   0 Members, 0 Anonymous, 4879 Guests (See full list)
