IH8PunkRok Posted December 16, 2010 Report Posted December 16, 2010 like the title says only half of each of my tubes is lit. i want to fix it but i am not sure what the issue might be. has anyone had this problem? or know how to fix it? ive tried to check all my connections (its routed very well). im pretty sure all tubes are connected well as they are very difficult to pull apart and were taped together as well. im trying to figure out if there is a broken lead in the lights somewhere or if the controller is the problem. i dont think it is the controller because i had the same problem with my old controller so i ordered a new one and the same problem still exists. any insights? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Ray Posted December 17, 2010 Report Posted December 17, 2010 broken wire at the start of the tube prob. they are hella tiny wires. pretty common 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
TheBetterMethod Posted December 17, 2010 Report Posted December 17, 2010 Are they green or omni colored? Probably a lead, like he said. ^ 2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3 The first build>>> http://www.stevemead...-outback-build/ 140.9 @ 36hz Sealed on dash! REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
Rogers Posted December 17, 2010 Report Posted December 17, 2010 led's correct? not neons? i know the bass fucks neons up... most likely a lead wire inside the tube itself... if you have warranty get them replaced http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
IH8PunkRok Posted December 17, 2010 Author Report Posted December 17, 2010 yes they are leds. multi color i dont have warranty. now here is a test i did that might throw a wrench in things. the flow of electricity goes control->drivers->rear->passenger->front i hooked the control straight to the front tube, the last in line. same thing happens. also the tubes are divided into 2 boards. on the side tubes only half is lit, just one board. on the front and back half is fully lit and then there is about 1/2 of the second board dimly lit. still think its a wire? or just a shitty control unit? -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
