dodge ram 5.9 magnum performance
have any of you with the 5.9 magnum done any engine upgrades? im going to have to do my intake gasket soon and wondering if anyone has used the hughes intake? used a different coil or distributor? or anything else that would help out in performance? i have done research on this but the dodge forum sucks... so i thought i would ask around here. thanks
  • 1 month later...
I have an 01 5.9 ram, all I have is a dual flowmaster on it, join ramforumz.com, great website you'll get Alot of help, I've been a member for a little bit.
2001 Dodge Ram
i will do that probably, its hard keeping track of all these forums lol. but i am going to be doing some work on it soon so i need to get up to speed on my research. thanks
i have an upgraded PCM for a 5.9 i could sell you real cheap. Itll make a pretty massive difference in how your truck performs
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
what brand and model number is it?
It was an upgraded PCM straight from Mopar here are some pics
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
what did you have this installed in and what was the difference it made to you?
It was installed in a 1999 Ram 1500 5.9 and it made a pretty huge difference, Makes the transmission shift alot faster and at a higher RPM when your on it, Makes throttle response quicker, it basically wakes your truck up from the sluggish factory settings. It also can improve gas mileage depending on how you drive.
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
and everything else still works the same? its a direct fit as in all the sensors and gauges and everything. cuz i have a 2500 with the plow prep package from the factory so it has a trans cooler and a power steering cooler, it also has over drive button, but i dont have power doors or locks or windows, or seats. will it still work? lol
