Also everything is in the trunk so it's only 3ft of cable from the amp to the battery. I am using the factory radio with a hi/lo filter. Could that be the problem?
Hi/Lo filters if they aren't powered take so much gain on the amp to get a strong voltage signal to the amp. Try one of these for a cleaner signal.
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=1&series_id=49&family_id=51&item_id=111123&locale=en_US&p_status=
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
well, guess you should have thought of that. with modern head units putting out 11-15 watts per channel those gains should be about a quarter of the way up...most come cranked to max from the factory. or worse...not matched
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
even pros forget about it. they usually forget about it, but since you had it done at a shop take it back there, explain the issue and ask them to take care of it. If they find that it's something they didn't do, then pay them for their time (probably $20 or so) for troubleshooting it, and go home and fix it, or pay them to fix it.
Principal
  • Who's Online   0 Members, 0 Anonymous, 1673 Guests (See full list)
